idosubaru Posted August 4, 2013 Share Posted August 4, 2013 (edited) 130,000 miles, automatic, XT6 - couple (2 or 3) rocker arms on the drivers side fell off after running the first time for a few minutes. it ran fine before the headgasket job. were they simply not pumped up or is something else wrong? i guess i'll install new HLA's in those positions that fell off - should i pay attention to or do anything else while I'm in there? i never prime them, never seemed to make a difference - i've always started and let the oil pump prime them. could that be to blame? Edited August 4, 2013 by grossgary Link to comment Share on other sites More sharing options...
NorthWet Posted August 4, 2013 Share Posted August 4, 2013 (edited) I can't imagine that the HLAs have enough stroke to allow the followers to fall off (I could well be mistaken). I would be more inclined to believe that the valves hung open. Did you just do the HGs, or did you also do some valve work? Edited August 5, 2013 by NorthWet Link to comment Share on other sites More sharing options...
man on the moon Posted August 5, 2013 Share Posted August 5, 2013 When installing the rocker arms, I always use a small dab of vaseline on both ends. It holds them in place and insures they aren't shifting a wee bit when you jimmy the cam into place. Beyond that...the HLA shouldn't relax enough to allow that, and as long as the other end is positioned over the valve end properly you should be ok. Was it one HLA, or all of them? Link to comment Share on other sites More sharing options...
Crazyeights Posted August 5, 2013 Share Posted August 5, 2013 (edited) Over the 30 or so years that I have been building and installing engines I have seen this happen a few times (to me and other techs). There doesn't seem to be a concrete reason and it usually never happens again once fixed and re-started. This isn't Subaru specific though. Hopefully it didn't cause any damage. Edited August 5, 2013 by Crazyeights Link to comment Share on other sites More sharing options...
Mark Humble Posted August 5, 2013 Share Posted August 5, 2013 Sticky valves. Lifters don't have enough travel to allow the followers to drop out. Mark Link to comment Share on other sites More sharing options...
idosubaru Posted August 5, 2013 Author Share Posted August 5, 2013 Sticky valves. Lifters don't have enough travel to allow the followers to drop out. seen this before on subaru's? they don't have enough room to squeeze them back in place now - so i guess they stuck right at start up, then freed up as i was running/trying to restart? I Did you just do the HGs, or did you also do some valve work? just headgaskets W Was it one HLA, or all of them? i think 3 of them. when assembly i greased them and made sure they were on before continuing. OHopefully it didn't cause any damage. non-interference and everything looks normal other than the arms slipping out. thanks for the feedback that you've seen it before, that's slightly comforting. Link to comment Share on other sites More sharing options...
