91 loyale exhaust issue, revisited
Hello, got some advice a couple months ago, but after replacing several front axle and bearing assembly parts, it was back burnered. My exhaust sound like a marble is rolling around above the front exhaust pipe right above the gaskets which i replaced. I hope I can post a vid on here... Any advice is much appreciated, I value your time.
Upon replacing the gaskets, there may have been foreign objects that slipped into the pipe.
-Pieces of old gasket
-Dirt, maybe rocks
-Washers, perhaps
Also, be sure that it's a noise that truly is coming from inside the pipe.
As opposed to... The off chance of a hanger or other piece of pipe/fitting vibrating against something else.
Take the pipe off and beam a flashlight into the abyss.
Suppose that's the next step.
Best of luck.
