79 4wd wheel bearings
Hi, new here and love what you guys are doing with the old Subies.  Does anyone know where (or how) to get wheel bearings for the front and the rear of a 79 4wd wagon?  I'm also looking for seals for the transaxle (axles and rear yoke) and the rearend.  I think I can get axles from rock auto but need the bearings and seals to get this back on the road safely.  Any help would be greatly appreciated!   -Jeff in PA
Thanks.  It looks like to me from my research that the inner and outer front wheel bearings are the same, and the inner and outer front wheel seals are the same part number as well.  I just need to reuse the spacer.  The outer bearings are a little different but I still need seals.  Are the inner and ouiter rear wheel bearing seals the same?  I know they are different from the fronts, but the same as each other?                         -Jeff
