tripletech263 Posted August 8, 2013 Share Posted August 8, 2013 new here, looking for some help. i have a 1991 subaru legacy sport. was replacing plugs in it and the front most passenger side spark plug hole was half full with oil. the car has been having a hesitation around 2500 rpm. i have seen the threads about the plug tube seals going out on the 2.5 motors but these don't appear to have the same set up and have not been able to find any seals at any parts stores or fiches. any help would be appriciated! Link to comment Share on other sites More sharing options...
heartless Posted August 8, 2013 Share Posted August 8, 2013 these are more than likely what you need: cam cover seals & grommets after 20+ years, these things get very hard and dont seal well anymore. Link to comment Share on other sites More sharing options...
Rooster2 Posted August 8, 2013 Share Posted August 8, 2013 Suggest you add a "stop leak" additive to your motor oil. The additive softens and swells old seals. My experience is that the various brands of additives will help a good deal, but not totally stop leaks. Link to comment Share on other sites More sharing options...
MilesFox Posted August 8, 2013 Share Posted August 8, 2013 There shoild be little drain holes casted into the heads. Lookout for dirt and leaves that my clog it up. Be careful not to get any funk down the threaded hole. Loosen up debris with a pik or screwdriver and blast it away with compressed air. Link to comment Share on other sites More sharing options...
tripletech263 Posted August 8, 2013 Author Share Posted August 8, 2013 i am picking up some valve cover gaskets tonight, they definetly need done. when i originally looked at it, it seemed as though the plug tubes were higher than the valve cover gasket area and wouldn't drain into them if they were leaking. i just wanted to make sure there wasn't anything else major that someone else had run into with this. thanks for the advice! Link to comment Share on other sites More sharing options...
Gloyale Posted August 8, 2013 Share Posted August 8, 2013 On 8/8/2013 at 3:04 PM, MilesFox said: There shoild be little drain holes casted into the heads. Lookout for dirt and leaves that my clog it up. Be careful not to get any funk down the threaded hole. Loosen up debris with a pik or screwdriver and blast it away with compressed air. No drain holes in the EJ engines. That's EA you are thinking of. Tripletech, I would guess that the PS pump or the Oil Pressure switch leaking is why the #1 plug hole is full of oil. Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 8, 2013 Share Posted August 8, 2013 On 8/8/2013 at 5:16 PM, Gloyale said: No drain holes in the EJ engines. That's EA you are thinking of. Tripletech, I would guess that the PS pump or the Oil Pressure switch leaking is why the #1 plug hole is full of oil. Agreed. Either of these can leak oil near the number one spark plug hole and fill it with oil. Link to comment Share on other sites More sharing options...
tripletech263 Posted August 8, 2013 Author Share Posted August 8, 2013 that would seem a little more plausible than the valve covers, but the valve covers need done regardless. when i'm installing those i will check both of those as well. again thanks for all the suggestions! Link to comment Share on other sites More sharing options...
