superu Posted August 13, 2013 Share Posted August 13, 2013 So I have a (lifted) 95 legacy. I've swapped its 15mm RSB for a gen 1 OB's RSB (18mm), thus I had the stock legacy bar laying around. Here's the fun part. I was laying under my wife's 03 OBS and looked at its measly 13mm RSB then thought, "Hmm. . . I wonder" So I grab the old 95 legacy stock RSB and hold it up. . . . remarkably similar I thinks!! So today, having her car in the garage since she took the legacy beast to work today (kid seats were in her car instead of mine today I jack it up pull of the RSB from the 03 OBS and line it up with the 95 legacy RSB. . . Mounting identical, bend for exhaust in the same place, a little longer bend in the legacy one for under the spare tire well, but hell they both have a spare tire well there...why not! With a couple 14mm nuts and bolts off and two 12mm SB mounting bolts off, I pulled it out and put the 15mm Legacy one in there. And LO, it mounted right up, with no contact on the bottom tire well!!! SOOOO, in summary, a gen 2 legacy/gen 1 OB RSB will mount up in a GD-GG (2000-2007) impreza body! Therefore, an easy RSB mod in these imprezas is to go from the factory (mine's an OBS wagon) 13mm RSB to a legacy 15 or even better, a legacy OB 18mm RSB!! retain the end links with the donor RSB and its bushings, but you can even keep your IMP SB mounting brackets. SCORE!! Link to comment Share on other sites More sharing options...
Caboobaroo Posted August 14, 2013 Share Posted August 14, 2013 Might want to swing the endlinks back up into the correct position. The swaybar ends should be above the rear lateral links. Overall though, easy and free mods are the best! Link to comment Share on other sites More sharing options...
superu Posted August 15, 2013 Author Share Posted August 15, 2013 (edited) Might want to swing the endlinks back up into the correct position. The swaybar ends should be above the rear lateral links. Overall though, easy and free mods are the best! AAh, thanks! It looked funny but I couldn't figure how... I didn't compare to my legacy, I just swapped and assumed I had the end links on correctly when I took off the other one. I see what you mean though aboiut proper positioning... I'll probably have to pull it from the brackets to get it in there, but still should be a snap. I'll have to do it late with hand tools after the wife's a sleep thanks! Edited August 15, 2013 by superu Link to comment Share on other sites More sharing options...
bratman18 Posted August 15, 2013 Share Posted August 15, 2013 Should be able to undo the endlinks, rotate the bar ends upwards into position, and then reattach the endlinks. Link to comment Share on other sites More sharing options...
superu Posted August 16, 2013 Author Share Posted August 16, 2013 done! 1 Link to comment Share on other sites More sharing options...
bratman18 Posted August 16, 2013 Share Posted August 16, 2013 Much better! Link to comment Share on other sites More sharing options...
superu Posted August 19, 2013 Author Share Posted August 19, 2013 (edited) Rear Sway Bar (RSB) quick disconnect upgrade for the off-road enthusiast!Two 14mm wrenchs and a 15mm wrench (leverage arm on one 14mm), PB, 3/8" by 2" clevis pin and "R"clipBest $2.73 mod for awesome off-road articulation!!! (PS: the other side is already installed) Edited August 19, 2013 by superu 1 Link to comment Share on other sites More sharing options...
