itmustbe_me Posted August 15, 2013 Share Posted August 15, 2013 I just purchased XXR wheels 17x8.25 with a 35mm offset. My subaru is a 2009 impreza 2.5i with stock height, i havent lowered it. I was wondering what size tires i should get that would fit my car best. Link to comment Share on other sites More sharing options...
Legacy777 Posted August 18, 2013 Share Posted August 18, 2013 Welcome to the USMB. I would suggest trying to keep the overall tire diameter the same. What size tires do you currently have on the car? You can use this tire calculator to input your old tire size and play around with new tire sizes that are close to the original size. http://www.miata.net/garage/tirecalc.html Link to comment Share on other sites More sharing options...
kevsev7k Posted August 22, 2013 Share Posted August 22, 2013 My 93 Impreza originally had 13" tires. I bought the car with 16" tires and when it came time to purchase new, due to the width of the tires they were expensive. I was given Legacy wheels size 15 and they have worked well for the past three years. I hope that helps. Link to comment Share on other sites More sharing options...
nickb21 Posted August 22, 2013 Share Posted August 22, 2013 (edited) Are you sure those rims will fit without rubbing the outside fender? I suppose they will if you go pretty narrow and pretty low-profile. Stock offset is around 53mm (give or take a mm or 2). I think the 17's on impreza's (and many subaru's) are only 7" wide. That means you'll be sticking out a whole bunch. You might tray over at Nabisco... I mean www.nasioc.com, they are much more geared to Impreza's and will probably have a FAQ on this exact question. EDIT: FAQs- http://forums.nasioc.com/forums/showthread.php?t=2208775 http://forums.nasioc.com/forums/showthread.php?t=335263 Looks like you might be able to roll with 225-245/40's. Maybe. Do some reading there, might need to roll the fenders. Good luck! Edited August 22, 2013 by nickb21 Link to comment Share on other sites More sharing options...
