kashkn Posted August 16, 2013 Share Posted August 16, 2013 I replaced the coil pak, spark plugs, don't know what else to do? Still getting check engine light Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 17, 2013 Share Posted August 17, 2013 Did you replace the plug wires too? What kind of spark plugs? Have you had the CEL scanned? Which codes are you getting? Link to comment Share on other sites More sharing options...
luko Posted August 17, 2013 Share Posted August 17, 2013 Bosch Platinum +4 plugs work great! But yeah make sure you either test your plug wires with an ohm meter or just replace them Link to comment Share on other sites More sharing options...
kashkn Posted August 18, 2013 Author Share Posted August 18, 2013 Sorry it took me so long, I'm getting codes 301 and 302. Link to comment Share on other sites More sharing options...
kashkn Posted August 18, 2013 Author Share Posted August 18, 2013 Ngk spark plugs as well Link to comment Share on other sites More sharing options...
Cougar Posted August 18, 2013 Share Posted August 18, 2013 Here is a link that you can study that may help you find a solution to the problem. http://www.aa1car.com/library/misfire.htm Link to comment Share on other sites More sharing options...
davebugs Posted August 22, 2013 Share Posted August 22, 2013 NGK plugs, the simple/cheap green ones. I've purchased more cars that run like crap due to Bosch Platinums that I should send Bosch a finders fee. And OEM plug wires. It's an old song, but a true song. 1 Link to comment Share on other sites More sharing options...
johnceggleston Posted August 22, 2013 Share Posted August 22, 2013 +1 what he said. Link to comment Share on other sites More sharing options...
ivans imports Posted August 22, 2013 Share Posted August 22, 2013 Valve addjustment ex valves are to tight get them before they burn ! Link to comment Share on other sites More sharing options...
ivans imports Posted August 22, 2013 Share Posted August 22, 2013 and if it dont say NGK throw it away Link to comment Share on other sites More sharing options...
