refueler1 Posted August 17, 2013 Share Posted August 17, 2013 Does the throttle body forget its settings if the battery is disconnected for a month or so. I know that some cars are like that. My 2000 legacy runs fine but it idles around 1500rpm and searches for the correct idle speed it varies about 500 rpm between 1000 and 1500 rpm Link to comment Share on other sites More sharing options...
MilesFox Posted August 17, 2013 Share Posted August 17, 2013 NO it does not. Perhaps the idle air control valve is stuck open, or there is a vacuum leak. Maybe you knocked something loose messing with the battery. DO NOT make any adjustments to the throttle body. 1 Link to comment Share on other sites More sharing options...
