AKghandi Posted August 20, 2013 Share Posted August 20, 2013 thinking about doing a reseal on my 87 ea82t. aside from gaskets,water pump, and timing belts, is there anything else I'm going to need? I want to do this as fast as possible, but not rush it. I want to buy everything I will need before I start, so I can get everything done on my day or two off. pulling the engine doesn't concern me, it will take me about an hour. What I'm talking about is thread taps, helicoils, rtv, which one for which gasket? more specifically, intake mani bolt helicoils, exhaust header bolt helicoil and if anyone knows off the top of their head the thread pitch for the thermostat housing bolts so I can helicoil those also. one has already been broken drilled and a different bolt put in its place, was a temp fix that has been working well but I want to fix it correctly. Link to comment Share on other sites More sharing options...
MilesFox Posted August 20, 2013 Share Posted August 20, 2013 I am trying to remember the diameter of the thermostat housing bolts, should be a 10mm head. If so, it will be m6x1.00 thread which is the samae as the WP and oil pump bolts. Otherwise it will be m8x1.25 if it has a 12mm head. the exhaust studs are m10x1.25 Use permatex ultra grey instead of RTV Link to comment Share on other sites More sharing options...
AKghandi Posted August 20, 2013 Author Share Posted August 20, 2013 thank you sir, You were just the person i was hoping to hear from. I'll be re watching all your videos before i start lol Link to comment Share on other sites More sharing options...
MR_Loyale Posted August 20, 2013 Share Posted August 20, 2013 (edited) I am trying to remember the diameter of the thermostat housing bolts, should be a 10mm head. If so, it will be m6x1.00 thread which is the samae as the WP and oil pump bolts. Otherwise it will be m8x1.25 if it has a 12mm head. the exhaust studs are m10x1.25 Use permatex ultra grey instead of RTV In September I am going to be doing head gaskets and probably a reseal while it is all out as well. It will be 35K miles since I last did a reseal in 2008, though I didn't do head gaskets then. Where all can I use the ultra grey? Cam towers etc? Edited August 20, 2013 by MR_Loyale Link to comment Share on other sites More sharing options...
MilesFox Posted August 20, 2013 Share Posted August 20, 2013 Use it on the cam tower, and small dabs on the il pump where it overlaps the crank halves. I like to use it on the pan side of the oil pan gasket. Install the thermostat gaset and the water pump gaskets dry 1 Link to comment Share on other sites More sharing options...
