the smell is coming from the inside of the vehicle? are you using the fresh air or recirculated (max ac). if you are using fresh air, its possible the clutch is slipping and the smell is traveling into the fresh air intake. of course you should be able to smell that under the hood, but maybe it has to be running at a fast enough rpm to slip and make the smell? it seems strange that its linked to the ac compressor itself, does the burnt smell, smell electrical or does it smell like a burnt clutch (smells like burning hair to me)
