kbs outback sport Posted August 20, 2013 Share Posted August 20, 2013 I have a 1998 Outback Sport (Impreza) that has just started blowing out a burning odor when the a/c compressor is turned on. No smell with just the fan and no unusual smells from within the engine compartment. Any ideas ? The car has very few miles for its age, about 60k. Link to comment Share on other sites More sharing options...
mikaleda Posted August 20, 2013 Share Posted August 20, 2013 the smell is coming from the inside of the vehicle? are you using the fresh air or recirculated (max ac). if you are using fresh air, its possible the clutch is slipping and the smell is traveling into the fresh air intake. of course you should be able to smell that under the hood, but maybe it has to be running at a fast enough rpm to slip and make the smell? it seems strange that its linked to the ac compressor itself, does the burnt smell, smell electrical or does it smell like a burnt clutch (smells like burning hair to me) Link to comment Share on other sites More sharing options...
nipper Posted August 20, 2013 Share Posted August 20, 2013 Does it do it with the blower motor on and the system on vent or heat? Can be a bad AC belt, a torn axle boot, oil leak bad compressor Link to comment Share on other sites More sharing options...
kbs outback sport Posted August 20, 2013 Author Share Posted August 20, 2013 There is no smell with just the blower motor. That was my first thought but nada with fan only at any speed. Its much worse with system set to recirculate but an odor drawing fresh air too. It smells more like a burning clutch than electrical. Link to comment Share on other sites More sharing options...
