BratRod Posted August 21, 2013 Share Posted August 21, 2013 (edited) Simple yes or no. I don't need any flaming. Searching was no help. Thanks. Edit: sorry, this is sorta urgent. Edited August 21, 2013 by BratRod 1 Link to comment Share on other sites More sharing options...
leniac Posted August 21, 2013 Share Posted August 21, 2013 nope Link to comment Share on other sites More sharing options...
silverhelme Posted August 21, 2013 Share Posted August 21, 2013 Should be the same except for the converter. The converter will work just has a slightly different stall speed. Link to comment Share on other sites More sharing options...
NorthWet Posted August 21, 2013 Share Posted August 21, 2013 Should be the same except for the converter. The converter will work just has a slightly different stall speed. This is also my understanding. I do not recall having heard anyone say that they were not interchangeable. Link to comment Share on other sites More sharing options...
ivans imports Posted August 21, 2013 Share Posted August 21, 2013 i belive the tail shaft is longer on ea81 trans but cant remember Link to comment Share on other sites More sharing options...
Gloyale Posted August 21, 2013 Share Posted August 21, 2013 Gear ratios can be different too. EA81s and early EA82 are 3.7 later ea82 are 3.9 Link to comment Share on other sites More sharing options...
BratRod Posted August 21, 2013 Author Share Posted August 21, 2013 Alright, thank you, guys. The reason I ask is, because there is some one who has a transmission for sale a couple hours away. Figured I could save a little on shipping if I could get him down on the price. http://dallas.craigslist.org/dal/pts/4010782624.html Link to comment Share on other sites More sharing options...
MilesFox Posted August 21, 2013 Share Posted August 21, 2013 It is possible to swap between . I have swapped an ea82 3at FWD into an ea81 hatch. It bolts up the same to the motor, but i had to fab a piece to adapt the rear part of the trans mount. Yu may have to mix'n'match the torque converter or the flexplate. Link to comment Share on other sites More sharing options...
silverhelme Posted August 22, 2013 Share Posted August 22, 2013 The flex plate and converter stay the same, use your original unless you have metal in the fluid. You can use an ea82 converter if you have to and it will bolt up but may have a different stall speed. Link to comment Share on other sites More sharing options...
ivans imports Posted August 22, 2013 Share Posted August 22, 2013 I still think is a tail shaft difference Link to comment Share on other sites More sharing options...
silverhelme Posted August 22, 2013 Share Posted August 22, 2013 You may be correct ivan. Interchange shows 84 down and 85 up. He may be able to swap the output shaft and housing if I remember correctly. Link to comment Share on other sites More sharing options...
86BRATMAN Posted August 22, 2013 Share Posted August 22, 2013 If you weren't so far away I'd give you the 3at in my basement to get it out of the way. Link to comment Share on other sites More sharing options...
BratRod Posted August 22, 2013 Author Share Posted August 22, 2013 Alright, guys. That's what I wanted to hear. The seller still hasn't responded back to me, though. I ended up finding a thread last night that someone just changed the stator shaft, and it worked. @86BRATMAN: That is very kind of you. I hate being so far away from Subaru parts, especially having two brats now! Id still take it if you feel like shipping it, but I figure there is a reason it is in the basement. Link to comment Share on other sites More sharing options...
86BRATMAN Posted August 22, 2013 Share Posted August 22, 2013 There is a perfectly good reason lol, I parted out an auto brat and thought it might come in handy just in case. I have no idea its condition other than the brat had around 90k miles, a seized engine, and no rear frame to hold anything up lol. I packrat stuff when I have the opporatunity. As far as shipping it, I don't have a problem with that if you wanted to do the leg work. I can provide an address and fork lift loading for pickup. And can probably get ahold of a good pallet, banding straps, and shrink wrap. Link to comment Share on other sites More sharing options...
BratRod Posted August 22, 2013 Author Share Posted August 22, 2013 Awesome! I'll work things out on my end and see what I can come up with. I'll drop you a PM with what I figure out. Link to comment Share on other sites More sharing options...
