redXTwedgie Posted August 21, 2013 Share Posted August 21, 2013 They are unplugged and I can't find from where. Many say they connect behind the drivers strut tower but I can't find anything anywhere under the hood. I unplugged them during my EJ swap and I'm wondering if they were connected to the motor that I pulled in some way. But I can't find anywhere to connect them on the motor either. Any ideas?? Link to comment Share on other sites More sharing options...
MilesFox Posted August 22, 2013 Share Posted August 22, 2013 The 4wd solenoids on the XT are on the firewall above the bellhousing, very near the wiper motor. the other end goes to the trans below the starter. Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted August 22, 2013 Share Posted August 22, 2013 (edited) ... could you post a Photo of the Engine Bay? ... Maybe you removed certain components along the EA Engine. Kind regards. Edited August 22, 2013 by Loyale 2.7 Turbo Link to comment Share on other sites More sharing options...
redXTwedgie Posted August 22, 2013 Author Share Posted August 22, 2013 On 8/22/2013 at 12:23 AM, Loyale 2.7 Turbo said: ... could you post a Photo of the Engine Bay? ... Maybe you removed certain components along the EA Engine. Kind regards. I still can't find anything. The hoses are long enough to reach the battery. Link to comment Share on other sites More sharing options...
redXTwedgie Posted August 22, 2013 Author Share Posted August 22, 2013 Link to comment Share on other sites More sharing options...
redXTwedgie Posted August 22, 2013 Author Share Posted August 22, 2013 Note: the hoses are connected at the bottom on the trans Link to comment Share on other sites More sharing options...
MilesFox Posted August 23, 2013 Share Posted August 23, 2013 It looks like it is missing. I see a threaded hole where your green relay is that it would mount to on a bracket. May be it got ditched having been mistaken for an emissions part. Link to comment Share on other sites More sharing options...
redXTwedgie Posted August 23, 2013 Author Share Posted August 23, 2013 Thanks, now I better go look for it. I can't figure out why I would have unplugged the hoses or removed the solenoids. Link to comment Share on other sites More sharing options...
redXTwedgie Posted August 23, 2013 Author Share Posted August 23, 2013 Now I remember. I thought it was smog stuff for the EA82. Found it in a bucket in the garage. Link to comment Share on other sites More sharing options...
TomRhere Posted August 23, 2013 Share Posted August 23, 2013 Those are the solenoids. There is another section of wiring harness for them though. About 10" long, all taped up, with matching White connectors that plugs between body harness and solenoids. That section of harness contains 2 diodes under all of the tape. Link to comment Share on other sites More sharing options...
redXTwedgie Posted September 24, 2013 Author Share Posted September 24, 2013 (edited) On 8/23/2013 at 11:12 AM, TomRhere said: Those are the solenoids. There is another section of wiring harness for them though. About 10" long, all taped up, with matching White connectors that plugs between body harness and solenoids. That section of harness contains 2 diodes under all of the tape. I'm 99% sure that part was not there when I got the car. 4wd did work before the swap. The two solenoid hoses that connect together with a check valve slightly downstream: where does the bottom end of that hose connect to? If anything... Edited September 24, 2013 by redXTwedgie Link to comment Share on other sites More sharing options...
TomRhere Posted September 25, 2013 Share Posted September 25, 2013 The hose would connect to a vacuum supply on the intake manifold. You can "tee" into an existing line if need be. Link to comment Share on other sites More sharing options...
ivans imports Posted September 25, 2013 Share Posted September 25, 2013 Should be a plastic vacume storage tank on fenderwell vacume to tank then to 4x4 soiliniond used long plastic lines just below the valance one side is 4x4 on one side is 4x4 off the vacume storage tank is important or will drop out of 4x4 under long accerations as engine makes low vacume at full trottle apps Link to comment Share on other sites More sharing options...
redXTwedgie Posted September 25, 2013 Author Share Posted September 25, 2013 On 9/25/2013 at 2:52 PM, ivans imports said: Should be a plastic vacume storage tank on fenderwell vacume to tank then to 4x4 soiliniond used long plastic lines just below the valance one side is 4x4 on one side is 4x4 off the vacume storage tank is important or will drop out of 4x4 under long accerations as engine makes low vacume at full trottle apps Thanks bro. You rock! Link to comment Share on other sites More sharing options...
redXTwedgie Posted September 25, 2013 Author Share Posted September 25, 2013 On 9/25/2013 at 8:44 AM, TomRhere said: The hose would connect to a vacuum supply on the intake manifold. You can "tee" into an existing line if need be. Sorry, I missed your post. Thank you so much. I can't find a cannister, so i'll try this. Link to comment Share on other sites More sharing options...
ivans imports Posted September 26, 2013 Share Posted September 26, 2013 on the intake ps side should be a removabble bung that can install a vacume fitting into the auto kickdown vacume fitting from loyale works good Link to comment Share on other sites More sharing options...
redXTwedgie Posted September 27, 2013 Author Share Posted September 27, 2013 I'm running an EJ22 manifold and there usually is a second tapped hole for a bung, but this one doesn't have one. I just teed it into the FPR hose to test it and it is back in 4WD. Is it cool to leave it on there? Thank you Tom and Ivans! Link to comment Share on other sites More sharing options...
TomRhere Posted September 28, 2013 Share Posted September 28, 2013 Ideally, you would want to run vac line to a storage canister, then out to the solenoids. Use a check valve in the line from vac source to canister. But with that said, I have the solenoid vac supply "Tee'd" in to the vac line to the canister line, before the canister. Not sure as to the "why" of it, but if I put the solenoid line after the canister, it messes with my heater controls. I'm running an XT6 FT4WD trans in mine, but the controls are identical between it and the Pushbutton 4WD trans. Link to comment Share on other sites More sharing options...
ivans imports Posted October 1, 2013 Share Posted October 1, 2013 I try to avoid useing the vacume line for regulator for anything but that is sensitve to changes in vacume ect it sould be direct to fuel reg no tees. Or you get rise in feul pershure when heater or 4x4 is turned on Link to comment Share on other sites More sharing options...
redXTwedgie Posted October 9, 2013 Author Share Posted October 9, 2013 Ok, thanks for the tips. I will find another place for it. Link to comment Share on other sites More sharing options...
