Crawlerdan Posted August 24, 2013 Share Posted August 24, 2013 99 outback- 2.5dohc. no knocking, pulled engine to replace hgs and timing, reinstall, now knocks what could i have done to cause this? Link to comment Share on other sites More sharing options...
davebugs Posted August 24, 2013 Share Posted August 24, 2013 You sure? By that I mean long ago folks here recommended MMO for noisey 2.2 and 2.5's after they have been setting for a whiel or after no oil - like a HG job for instance. MMO and a spirited drive helps a lot. But usually that's cams n stuff. Top end noises. Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 24, 2013 Share Posted August 24, 2013 How fast does the oil pressure light turn off after starting? When you took the heads off did you pull all of the shims out of the buckets for the valves? The shims set valve lash clearance and can not get mixed up. They have to go back exactly where they came from. Link to comment Share on other sites More sharing options...
davebugs Posted August 24, 2013 Share Posted August 24, 2013 How fast does the oil pressure light turn off after starting? When you took the heads off did you pull all of the shims out of the buckets for the valves? The shims set valve lash clearance and can not get mixed up. They have to go back exactly where they came from. I believe a 99 is pure HLA, not shims like 97's. Link to comment Share on other sites More sharing options...
Crawlerdan Posted August 24, 2013 Author Share Posted August 24, 2013 i put all the shims back where they went, oil pressure cant shut off fast enough. i went out and beat it like it owed me money- noise bubye violence solves everything! 2 Link to comment Share on other sites More sharing options...
davebugs Posted August 24, 2013 Share Posted August 24, 2013 MMO and a spirited drive always did it for me. Had never used MMO before Subaru's. Link to comment Share on other sites More sharing options...
idosubaru Posted August 24, 2013 Share Posted August 24, 2013 "like it owed me money" LOL, awesome, glad you got it. tensioner can slap and sound incredibly similar to a knock. Link to comment Share on other sites More sharing options...
