redXTwedgie Posted August 25, 2013 Share Posted August 25, 2013 Block 97 EJ25D Everthing else is 95 EJ22E Cometic HGs Delta Cams Worked one night, but not the next morning. It was running hot and probably detonated. Has spark and gas but no compression. I pulled the head and isn't apparently evident why there is no compression. Exhaust valves are much darker on 3 than 1. Link to comment Share on other sites More sharing options...
redXTwedgie Posted August 25, 2013 Author Share Posted August 25, 2013 Cam operation of valves looks normal. Here is the block. Not much to see here. What's next?? Link to comment Share on other sites More sharing options...
Gloyale Posted August 25, 2013 Share Posted August 25, 2013 (edited) Dry the head thoroughly. Set the head with the exhaust ports up. and fill the exhaust chamber with brake clean, or mineral spirits, or carb cleaner or whatever. Some thin solvent. Watch the valve area (combustion chamber side) for any signs of leakage past the valves. Leave it overnight, 90 percent of the liquid should still be there, and no signs of wetness past the valves. If the exhaust pass, repeat for the intake valves. If the valves pass, inspect the headgasket again for any signs it had failed and was no holding compression. If that is good, then suspect the piston. pull the engine, the seperator plate, and then pull the wrist pin and piston for #3. Edited August 25, 2013 by Gloyale Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 26, 2013 Share Posted August 26, 2013 I've had the hydraulic lifters pump up too much and hang the valves open. Check the drain ports on the rocker arms for obstruction, also remove and clean the lifters. Link to comment Share on other sites More sharing options...
redXTwedgie Posted August 26, 2013 Author Share Posted August 26, 2013 Dry the head thoroughly. Set the head with the exhaust ports up. and fill the exhaust chamber with brake clean, or mineral spirits, or carb cleaner or whatever. Some thin solvent. Watch the valve area (combustion chamber side) for any signs of leakage past the valves. Leave it overnight, 90 percent of the liquid should still be there, and no signs of wetness past the valves. You nailed it again! It just started pouring out of the exhaust valves. I wipe it dry and the combustion chamber is covered again in 15 or 20 seconds. Looks bad enough to produce 0 compression, I would think. Thanks again Dan. I'll probably run out to pnp and grab a head tomorrow. $50 w/o cam. Hopefully I can get out of this pretty cheap. So what, I just overheated those springs and they weakened and can't keep the valve closed anymore? Link to comment Share on other sites More sharing options...
lmdew Posted August 26, 2013 Share Posted August 26, 2013 Don't forget to tighten the lower engine stud nut when you are all done. If you don't find a good head I have a set in Colorado Springs. Larry Link to comment Share on other sites More sharing options...
ivans imports Posted August 26, 2013 Share Posted August 26, 2013 Hlas stuck wide open relase the oil preshure by removing hla and pushing in the ball on bottom and pumping the oil out at same time then can start with them down all the way and let them addjust Link to comment Share on other sites More sharing options...
redXTwedgie Posted August 26, 2013 Author Share Posted August 26, 2013 Thanks Fairtax and Ivan. I'm gonna give that a shot before doing anything else. Link to comment Share on other sites More sharing options...
Fairtax4me Posted August 26, 2013 Share Posted August 26, 2013 That's a simple check really. Just remove the rocker arm assembly from the head and recheck the leaking valves. Might want to compress the springs a bit and make sure nothing is wedged in the valve seats (carbon/crud). Link to comment Share on other sites More sharing options...
redXTwedgie Posted August 26, 2013 Author Share Posted August 26, 2013 The HLAs seemed ok; I went and grabbed a new head and slapped it on. Tomorrow I'll run a comp test again. Link to comment Share on other sites More sharing options...
redXTwedgie Posted August 27, 2013 Author Share Posted August 27, 2013 Compression has returned and it's running good again. YEEHAW! Link to comment Share on other sites More sharing options...
ivans imports Posted August 28, 2013 Share Posted August 28, 2013 Did you pull the valves to see what the problem was ? bent ? Link to comment Share on other sites More sharing options...
redXTwedgie Posted September 1, 2013 Author Share Posted September 1, 2013 Did you pull the valves to see what the problem was ? bent ? They didn't appear bent or damaged in any way. Looks like the springs just couldn't keep them completely closed Link to comment Share on other sites More sharing options...
capn_r Posted September 1, 2013 Share Posted September 1, 2013 Possible loosened valve guides? Link to comment Share on other sites More sharing options...
ivans imports Posted September 3, 2013 Share Posted September 3, 2013 did you clean and check for stuck hlas Link to comment Share on other sites More sharing options...
