belacane Posted August 30, 2013 Share Posted August 30, 2013 (edited) Hey all, Replaced my drivers side wheel bearings, cv axle and ball joint this week on my '86 Brat. Everything went well until I started putting everything back together.... The bracket, which attaches to the steering knuckle, rubs on the brake rotor, as seen in the picture below. All bolts are tightened and in place and I'm 100% sure the caliper bracket is not bent. Here's a picture of where it's rubbing: I'm a little bit worried I actually messed up / bent the knuckle, while I was using a hydraulic press to get the wheel bearings out of it. It took me putting far too much pressure (10 tons) on the wheel bearings from one side to realize that there's a casting ridge in the middle of the knuckle and that the bearings needed to be pushed out from the center. After that was realized, they came out and went back in fine. But is it possible that I've bent the ears on the knuckle from too much pressure and that's why the caliper bracket is not fitting correctly? Any hints, tips....etc. would be greatly helpful eep! Edited August 31, 2013 by belacane Link to comment Share on other sites More sharing options...
maozebong Posted August 30, 2013 Share Posted August 30, 2013 looks like you bent it.... if it rubs consistently around the whole disc while turning the hub, id say its bent, or you have something betwixt the hub and rotor. Link to comment Share on other sites More sharing options...
belacane Posted August 31, 2013 Author Share Posted August 31, 2013 Crap, thats what I thought. Gonna try and torch it and bend it back....let's see how that goes... Link to comment Share on other sites More sharing options...
