91LegacyL233kmiles Posted August 31, 2013 Share Posted August 31, 2013 I have a 91 Legacy L and my cooling fans aren't automatically turning on. I have no cooling fans running at the moment and need to fix this ASAP. Quote Link to comment Share on other sites More sharing options...
okamikai Posted August 31, 2013 Share Posted August 31, 2013 Did you check the fan relay? If it is bad or burnt the fans will not turn on when the temperature rises. If you can, make a connection directly to the battery so you can rule out that the fans are bad. Also try turning the AC on this should activate the relay, if it doesn't the relay is bad. Just in case check for bad wiring and connectors as they may go bad with time. I hope this is useful to you. Quote Link to comment Share on other sites More sharing options...
