4play Posted September 3, 2013 Share Posted September 3, 2013 I have a 89 gl wagon,ej 22 swap, starts fine runs great for about 5 minites, then runs like crap, pops backfire, and shakes. I am at a loss what to do. thanks if you can help. Link to comment Share on other sites More sharing options...
idosubaru Posted September 3, 2013 Share Posted September 3, 2013 read the check engine codes? front O2 sensor itself is hosed or the wiring is exposed and shorting out against something? ECU doesn't use the front O2 sensor until operating temperature...so maybe? disconnect it and see if that changes how it runs? might want to mention what kind of EJ22 you're running? 90-94, 95-98, 99-01 block...and then what ECU? Link to comment Share on other sites More sharing options...
4play Posted September 3, 2013 Author Share Posted September 3, 2013 ok thanks, ther are no codes, I know the check engin lite works, it is a 90 ej 2.2 with the the ecu from the same car. it only has one o2 sensor. thanks agin. Link to comment Share on other sites More sharing options...
4play Posted September 13, 2013 Author Share Posted September 13, 2013 enter net has been down ,I have not got this figured out yet, need advice. Link to comment Share on other sites More sharing options...
Uberoo Posted September 14, 2013 Share Posted September 14, 2013 What fuel pump do you have?It sounds like at the five minute mark your not getting fuel.So either there isn't voltage to the pump or the pump isn't rated for a high enough head pressure.You can check if thats your issue by clamping your return line and see if it helps.if it does your fuel pump may be dieing. Link to comment Share on other sites More sharing options...
4play Posted September 14, 2013 Author Share Posted September 14, 2013 Ok thanks, but it is new ,from autozone,e2000 model 45 to 90 psi, but I will clamp the return and see what happens, I was told to check the coolant temp sencer, so I unpluged it, it throws that code right after start up, it also omes out ok. I think what ever tells it to chock its self when cold is not shuting off when it gets warm.? thanks Link to comment Share on other sites More sharing options...
Gloyale Posted September 14, 2013 Share Posted September 14, 2013 Ok thanks, but it is new ,from autozone,e2000 model 45 to 90 psi, but I will clamp the return and see what happens, I was told to check the coolant temp sencer, so I unpluged it, it throws that code right after start up, it also omes out ok. I think what ever tells it to chock its self when cold is not shuting off when it gets warm.? thanks Those would be the O2 sensor and the Coolant temp sensor. I am thinking you've got a vaccum leak on the EVAP solenoid circuit. When it opend to vent the canister after warmup, it is opening the Vac leak. Jsut a though. How do you have your evap system set-up? do you have a canister in place? Link to comment Share on other sites More sharing options...
4play Posted September 14, 2013 Author Share Posted September 14, 2013 (edited) The fuel pump has enuf psi. evap system? it is gone. is that what the 2 hard lines under the manifold are? comes out on the left side frunt of moter. thay are pluged off. thanks for any help. Edited September 14, 2013 by 4play Link to comment Share on other sites More sharing options...
Gloyale Posted September 14, 2013 Share Posted September 14, 2013 It's not gone. You still have a Evap solenoid located under the #1/3 intake runners. Check that the solenoid is not broken, disconnected, etc... The hardlines you mentioned are indeed for the evap. The larger one is the vent line from the tank, the smaller one goes to the solenoid, which when it opens connects to the intake. Pluggin the lines may work. The evap may not be the problem. But IMO, FWIW, that you should install a canister from a Legacy. Nothing to lose. I focus on the EVAP system because it's the one system that "opens" or on;y comes into play once warmed up. Link to comment Share on other sites More sharing options...
4play Posted September 14, 2013 Author Share Posted September 14, 2013 Ok thanks, I will look for that solenoid. Link to comment Share on other sites More sharing options...
4play Posted September 14, 2013 Author Share Posted September 14, 2013 ok that solenoid duse nuthing, hooked up or not, ther is no change. I have unpluged most every thing to see if it will show a code, and every thing did except the 02 cencer, so I think I need to see why. Link to comment Share on other sites More sharing options...
4play Posted September 29, 2013 Author Share Posted September 29, 2013 Ok so this still giving me a head ake, I changed the 02 censer it runns better but still not right.any more thots on what to check. Link to comment Share on other sites More sharing options...
