ebibb Posted September 3, 2013 Share Posted September 3, 2013 I have a 1995 Subaru Legacy L s/w and replaced the A/C belt last summer after replacing the power steering pump. Ever since then, the A/C belt has squealed either when turning on the A/C or driving after it's on. It usually only lasts for 10 - 20 seconds, although there are times when it just won't stop and I have to go without A/C for a little while. As the squeal goes away, it sounds like a belt noise fading out, however, I know it could be something else entirely. The belt is tight so it's not a loose belt thing, but I don't know what else it could be. Any ideas? Link to comment Share on other sites More sharing options...
luko Posted September 3, 2013 Share Posted September 3, 2013 Just how tight is the belt though? like how much play is in it? There is also a torque spec for it as well 1 Link to comment Share on other sites More sharing options...
okamikai Posted September 3, 2013 Share Posted September 3, 2013 I've seen this before, sometimes it doesn't matter if you replace the belt it may squeal a little, but not for that long. Another thing you should look at is the A/C pulley, when the compressor bearings wear out they will slow down the pulley's rotation, but since the engine will not stop for that it will force the belt to slip on the pulley's surface. Take the belt off and check if that stops the noise, if it does you found your problem. Hope this can be of help. Link to comment Share on other sites More sharing options...
john in KY Posted September 4, 2013 Share Posted September 4, 2013 Belt needs to be replaced, now glazed, and adjusted correctly. Link to comment Share on other sites More sharing options...
ebibb Posted September 6, 2013 Author Share Posted September 6, 2013 Luko, Okamakai, and john in KY, The belt is pretty tight, maybe 1/2" total play. I didn't check for torque speck though. I guess I'm still old school. I'll try replacing the belt first and while I have it off I'll see if the A/C unit still squeals. Thanks for all of the suggestions! ebibb Link to comment Share on other sites More sharing options...
Downbound Posted September 6, 2013 Share Posted September 6, 2013 Had exactly the same whine in my 2001 forester. Turned out to be the AC idler pully, also needed to repair the tensioner mount. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted September 6, 2013 Share Posted September 6, 2013 they didn't sell you one of those new stretch-type belts by mistake did they? Link to comment Share on other sites More sharing options...
porcupine73 Posted September 13, 2013 Share Posted September 13, 2013 Sometimes the a/c compressor clutch will squeal for a moment when it kicks in but usually I don't think it would be a continuous squealing. Link to comment Share on other sites More sharing options...
nipper Posted September 14, 2013 Share Posted September 14, 2013 Belt is slipping, check the idler pully assembly. not unusual for them to go bad when they are this old. Link to comment Share on other sites More sharing options...
ebibb Posted June 18, 2014 Author Share Posted June 18, 2014 Sorry to have been offline for so long. Sometimes life gets in the way. I did not replace the belt, just checked the tightness as it started to get into the colder part of the season without need of the A/C. Okay, here are a few more symptoms with the belt noise problems. Every day when I crank the car the belt squeals automatically. The only way to stop the noise without waking up the neighbors is to put the vehicle in gear which stops the noise. When driving with the air on, it squeals with regularity. It will go away by releasing the gas pedal or, at times, by giving more gas. Now, here's something odd. When sitting in traffic or anyplace with the engine idling, it does not squeal at all, although, when taking off again, the squeal may return. I hope this will narrow down the problem a little. I don't want to overspend or buy the wrong parts to repair the problem. Any ideas? Thanks, ebibb Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 18, 2014 Share Posted June 18, 2014 I think you should inspect the crank pulley for separation. Link to comment Share on other sites More sharing options...
Fairtax4me Posted June 18, 2014 Share Posted June 18, 2014 Belt is loose. Possibly the bearing in the tensioner is going bad. If the belt has been squealing for some time, its probably glazed now and will need to be replaced. Link to comment Share on other sites More sharing options...
1 Lucky Texan Posted June 19, 2014 Share Posted June 19, 2014 if it does it reliably after you start and idle in the mornings, you could 'probably' prove it's the belt again by spraying something like this on it; Link to comment Share on other sites More sharing options...
