Scott in Bellingham Posted September 4, 2013 Share Posted September 4, 2013 Ok here it goes made a deal on a 90 legacy has the 2.2 with a 5 speed, its a wagon, been sitting a couple years I jump started it and it started right up got to love them FI computerized engines, the guy parked it cause the clutch gave out on him, it has a water leak somewhere the front floors have green stuff growing on them, heres some parts that will go into this 4.37 Toyota 3rd with a locker thanks Kev for setting her up for me couple 33" tires for the rear Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 4, 2013 Author Share Posted September 4, 2013 made a little progress this morning Link to comment Share on other sites More sharing options...
monstaru Posted September 4, 2013 Share Posted September 4, 2013 You can actually cut the bottom inch out of that pumpkin and still clear the diff ring gear.It equates to about 2 tire sizes of clearance. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 4, 2013 Author Share Posted September 4, 2013 You can actually cut the bottom inch out of that pumpkin and still clear the diff ring gear.It equates to about 2 tire sizes of clearance. thanks I know, would have added 1" , but didn't want to take all day on it Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 5, 2013 Author Share Posted September 5, 2013 front hub adapters to fit 6 bolt wheels Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 6, 2013 Author Share Posted September 6, 2013 playin with springs, this is the fun part. maybe use the stock springs at a angle, looks like they have 5-1/2" travel and with the rear chopped off will be to stiff, so at a angle the travel will be greater , still in the idea fase, maybe chop off them leaf springs and they will act as forward links with flex, will need a ladderbar or something to prevent the rearend from twisting and maybe a panhard bar, will see as this develops Link to comment Share on other sites More sharing options...
ryot1 Posted September 6, 2013 Share Posted September 6, 2013 cannot wait to see this!!!!!!!! Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 7, 2013 Author Share Posted September 7, 2013 (edited) got the rear springs shortened , these are front Toyota lift springs , these wont be springs but forward links front a-arms will need strengthened plan to add a 3rd pivot point up front and add a brace to the A Arm Edited September 7, 2013 by Scott in Bellingham Link to comment Share on other sites More sharing options...
Gloyale Posted September 7, 2013 Share Posted September 7, 2013 plan to add a 3rd pivot point up front and add a brace to the A Arm I like it all. But I'm wondering if your 3rd pivot/brace shown here might interfere with the steering rack? Might need to make that brace arc shaped to fit over the inner tierods. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 8, 2013 Author Share Posted September 8, 2013 I like it all. But I'm wondering if your 3rd pivot/brace shown here might interfere with the steering rack? Might need to make that brace arc shaped to fit over the inner tierods. Illl be designing it on the complete car Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 8, 2013 Author Share Posted September 8, 2013 (edited) Picked up the car Bobbed the rear Edited September 8, 2013 by Scott in Bellingham Link to comment Share on other sites More sharing options...
ryot1 Posted September 9, 2013 Share Posted September 9, 2013 nice ...gotta lot done Link to comment Share on other sites More sharing options...
ryot1 Posted September 9, 2013 Share Posted September 9, 2013 i like your rear links very good mod Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 10, 2013 Author Share Posted September 10, 2013 got more done 1 Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 11, 2013 Author Share Posted September 11, 2013 (edited) mo pics wheel spacer 1-1/2" a side 3" total Outback struts gives more room for larger diameter tires Edited September 11, 2013 by Scott in Bellingham Link to comment Share on other sites More sharing options...
tron Posted September 12, 2013 Share Posted September 12, 2013 So sweet man! Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 13, 2013 Author Share Posted September 13, 2013 mo pics Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 15, 2013 Author Share Posted September 15, 2013 (edited) got the rear axle in position, the fronts all hooked up, now for the fun part springs looks like the front will end up with about a 10-11 inch lift to level it out Edited September 15, 2013 by Scott in Bellingham Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 15, 2013 Author Share Posted September 15, 2013 been 1 week on this so far, happy with the progress and the results, hope to have it usable within a couple weeks, its been awhile since I went out wheelin, it was last winter up in the snow last time I was out, I thought I had a set of Impreza FWD axles but Ive misplaced them in my shop somewhere, Ill need them when I put the dualrange in, Ill set up the rear and then build the front to match, looks like at least a 10" lift , the rear will get the hatch put back on shortened a bunch Link to comment Share on other sites More sharing options...
Gloyale Posted September 15, 2013 Share Posted September 15, 2013 Looks nice with that axle back there. (nver thought I'd say that about a subaru) at any rate will be a fun ride I wonder about axle wrap and side slip. Any triangulation in the works? Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 15, 2013 Author Share Posted September 15, 2013 Looks nice with that axle back there. (nver thought I'd say that about a subaru) at any rate will be a fun ride I wonder about axle wrap and side slip. Any triangulation in the works? yes it will have a panhard rod, and a bar to stop axle rap Link to comment Share on other sites More sharing options...
Uberoo Posted September 16, 2013 Share Posted September 16, 2013 yes it will have a panhard rod, and a bar to stop axle rap With that in mind why run the leaf springs at all and instead set up a 3 link?Just use the struts you have already to suspend it. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 17, 2013 Author Share Posted September 17, 2013 With that in mind why run the leaf springs at all and instead set up a 3 link?Just use the struts you have already to suspend it. Ialready have the leafs and they will act as a swaybar a bit Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 17, 2013 Author Share Posted September 17, 2013 got some trimming to do Link to comment Share on other sites More sharing options...
ryot1 Posted September 17, 2013 Share Posted September 17, 2013 i like Link to comment Share on other sites More sharing options...
