ryot1 Posted October 1, 2013 Share Posted October 1, 2013 fabricate a long arm kit for the front with custom axles Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted October 2, 2013 Author Share Posted October 2, 2013 yes the EJ starter is shorter Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted October 2, 2013 Author Share Posted October 2, 2013 (edited) got the tranny mount almost done , moved up the drivers side mount Edited October 2, 2013 by Scott in Bellingham Quote Link to comment Share on other sites More sharing options...
Uberoo Posted October 2, 2013 Share Posted October 2, 2013 yes the EJ starter is shorter very nice,for my T case setup that means I can mount the engine just a little further back. Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted October 5, 2013 Author Share Posted October 5, 2013 (edited) looks like I may drive this Hog Tomorrow, today I tidied up the engine compartment, lengthened a heater hose, a gas hose, moved some wires around, moved the rad top forward 1/2", lengthened the steering knuckle, mounted a 2000 Y pipe in, looks more like a U-pipe ,bought a rad hose, so looks like shifting linkage, driveline, rear track bar and its a driver, been just over a month so far, still got tons left to do , hope to hit the trails in a couple weeks Edited October 5, 2013 by Scott in Bellingham Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted October 5, 2013 Author Share Posted October 5, 2013 (edited) MO PICS stock 90 y pipe top, 2000 2.5 pipe on bottom, went with the 2000 as is shorter and Ill be mounting the exhaust up high over the tranny crossmember and un against the body went to O Reilly's and found a hose that made both top and lower hose , they have literally 100s of hoses to choose from Edited October 5, 2013 by Scott in Bellingham Quote Link to comment Share on other sites More sharing options...
ryot1 Posted October 6, 2013 Share Posted October 6, 2013 spray paint her florescent yellow on black wheels Quote Link to comment Share on other sites More sharing options...
Uberoo Posted October 7, 2013 Share Posted October 7, 2013 (edited) spray paint her florescent yellow on black wheels how about black with florescent yellow wheels and lift blocks? Edited October 7, 2013 by Uberoo Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted October 10, 2013 Author Share Posted October 10, 2013 it drives still got 100 things to do, 2 Quote Link to comment Share on other sites More sharing options...
ryot1 Posted October 10, 2013 Share Posted October 10, 2013 nice Quote Link to comment Share on other sites More sharing options...
Uberoo Posted October 11, 2013 Share Posted October 11, 2013 shorten the front now, it looks out of place with the non existant rear. Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted October 11, 2013 Author Share Posted October 11, 2013 shorten the front now, it looks out of place with the non existant rear. would like to, theres a rad and engine in the way, will be modifying bumper . got the track bar all in, got the rear brakes hookup up and fixed, workin on the driveline now Quote Link to comment Share on other sites More sharing options...
monstaru Posted October 12, 2013 Share Posted October 12, 2013 The problem is , not wanting to just step away from Subaru...LOL Then at least you could have some real suspension. cheers 3 Quote Link to comment Share on other sites More sharing options...
monstaru Posted October 12, 2013 Share Posted October 12, 2013 The problem is , not wanting to just step away from Subaru...LOL Then at least you could have some real suspension. cheers Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted October 12, 2013 Author Share Posted October 12, 2013 The problem is , not wanting to just step away from Subaru...LOL Then at least you could have some real suspension. cheers I like the Subaru and hey its makin me a living, should hit the trail next weekend , still want to take a dualrange and add some real lower gears in the low range area, might take some welding and machine work with some added parts Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted October 13, 2013 Author Share Posted October 13, 2013 drivelines in Quote Link to comment Share on other sites More sharing options...
czny Posted October 14, 2013 Share Posted October 14, 2013 How many degrees of motion do you have in that driveshaft center joint & what vehicle was the donor? Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted October 14, 2013 Author Share Posted October 14, 2013 How many degrees of motion do you have in that driveshaft center joint & what vehicle was the donor? the front is stock 90 Subaru wagon from the car, rear u-joint and flange is Toyota pickup, not sure motion, it does have forward/reverse movement, its like a cv joint Quote Link to comment Share on other sites More sharing options...
monstaru Posted October 14, 2013 Share Posted October 14, 2013 more gusset at the pan hard mount frame wise . Like . A LOT. Both sides. I just keep wanting you to build something that will last. Why won't you ? lol Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted October 14, 2013 Author Share Posted October 14, 2013 more gusset at the pan hard mount frame wise . Like . A LOT. Both sides. I just keep wanting you to build something that will last. Why won't you ? lol Hmmm I thought you might notice that Quote Link to comment Share on other sites More sharing options...
czny Posted October 14, 2013 Share Posted October 14, 2013 Ah, I get it...the center is a trunion joint. Correct? Quote Link to comment Share on other sites More sharing options...
Gloyale Posted October 14, 2013 Share Posted October 14, 2013 Ah, I get it...the center is a trunion joint. Correct? It's a DOJ type CV. Looks like a late 90's legacy driveline. Some models have this type, others it's just a Ujoint. My thought is that it won't have enough slip. it's not a slip yoke. When that axle starts going up and down that joint may not have enough travel. Scott, look into Nissan and Izuzu drivelines. Same input ends at the trans, and flange at the axle. Get 2wd model one from nissan will have slip section in it. Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted October 17, 2013 Author Share Posted October 17, 2013 (edited) getting there Edited October 17, 2013 by Scott in Bellingham 1 Quote Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted October 20, 2013 Author Share Posted October 20, 2013 got her road worthy and went to walker , I really like the car, drive easy , good performance, 1 Quote Link to comment Share on other sites More sharing options...
ferox Posted October 20, 2013 Share Posted October 20, 2013 Looks good. How was it for road manners? I'm guessing a front tube bumper is in the plans. Quote Link to comment Share on other sites More sharing options...
