Scott in Bellingham Posted September 18, 2013 Author Share Posted September 18, 2013 almost Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 19, 2013 Author Share Posted September 19, 2013 shortened the rear lid 8" 2 Link to comment Share on other sites More sharing options...
AdventureSubaru Posted September 19, 2013 Share Posted September 19, 2013 You could back that thing up a cliff with that rear approach angle! Looking good! Seems to be rolling right along. Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 21, 2013 Author Share Posted September 21, 2013 mo pics Link to comment Share on other sites More sharing options...
matts87glsedan Posted September 21, 2013 Share Posted September 21, 2013 (edited) looks rad whats the master plan for mounting the front of the spring? if you just stick a bolt through it, wont the axle try to twist it off when it articulates? or will the bushing be good enough to absorb that twist... *went back thru the pics* ok so nvmd it is bolted thru... i suppose this unit isnt going to have crazy rock crawler axle travel anyway, so maybe it doesnt matter so much. Edited September 21, 2013 by matts87glsedan Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 24, 2013 Author Share Posted September 24, 2013 (edited) sitting on its own springs in the rear, these are EA82 rear wagon springs, seem a little stiff, I have a set of ea82 fwd sedan springs that are lighter, may put them on , will know more after the car is drivable, its a roller again now onto the front, still haven't found my set of axles Ill need for the Dualrange swap, need to clean the shop, the weather has turned been rainy, cant wait to get this thing on the trail, Edited September 24, 2013 by Scott in Bellingham Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 24, 2013 Author Share Posted September 24, 2013 (edited) short list dual winches, 8000 Warn up front, 5000 Viper ATV winch rear 29" TSLs up front, not shures on rear 32" 88 EA82 Dualrange 3.9 swap EJ 2.2 stock, Delta low torx cams later rear Toyota axle with lockrite locker sliders, exocage, bumpers CB radio Hamm radio rear 1/2 seat will make storage spot behind drivers seat separate from passenger compartment to keep stuff from flying around stronger front a-arms with added pivot point onboard air with extra tank tow hitch in rear Im trying to put into this all the stuff I wished I had on my other rigs Edited September 24, 2013 by Scott in Bellingham Link to comment Share on other sites More sharing options...
AdventureSubaru Posted September 24, 2013 Share Posted September 24, 2013 Autozone has the Duralast reman 2WD Impreza axles for $44.99 + a core. Junk yards around here want $35. for a used one. Link to comment Share on other sites More sharing options...
monstaru Posted September 24, 2013 Share Posted September 24, 2013 If you do not add a panhard bar you will end up ripping those shock mounts off. You WILL have side to side movement with those springs. 1 Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 25, 2013 Author Share Posted September 25, 2013 (edited) went with 8" strut extensions, I had a set of 5" from a Impreza I had , so I added 3" with the Outback struts for a overall 9" Lift Edited September 25, 2013 by Scott in Bellingham 1 Link to comment Share on other sites More sharing options...
ezapar Posted September 25, 2013 Share Posted September 25, 2013 Um Scott. . . Where's the gas tank gonna go? 1 Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 25, 2013 Author Share Posted September 25, 2013 Um Scott. . . Where's the gas tank gonna go? its till in the stock place under the rear seat Link to comment Share on other sites More sharing options...
monstaru Posted September 26, 2013 Share Posted September 26, 2013 (edited) Um Scott. . . Where's the gas tank gonna go? Just like a jeep, in the back.. He keeps saying he wants to build a solid wheeler , but refuses to adhere to certain rules. lol Any one can build spoob fast.......... Build something that lasts Scott, I know you can!lol Edited September 26, 2013 by monstaru 1 Link to comment Share on other sites More sharing options...
Gloyale Posted September 26, 2013 Share Posted September 26, 2013 Uh.....Guys.....the gas tank is still there. Don't you guys see it? Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 27, 2013 Author Share Posted September 27, 2013 (edited) got the front lift supports in will be adding bracing to these later Doner tranny 86 GL Milled out new pattern to match the EJ engine Stock 90 AWD 5 speed on top Dual range from 86 GL 4x4 trans on the bottom, the dual range takes a smaller diameter clutch and flywheel front 5" block welded to 2x3 tubing, when finished the tubing will be part of subframe Edited September 27, 2013 by Scott in Bellingham Link to comment Share on other sites More sharing options...
tron Posted September 27, 2013 Share Posted September 27, 2013 Nice to see fern has donated to the project! awesome scott! Link to comment Share on other sites More sharing options...
mcbrat Posted September 27, 2013 Share Posted September 27, 2013 Subscribed 1 Link to comment Share on other sites More sharing options...
ezapar Posted September 28, 2013 Share Posted September 28, 2013 its till in the stock place under the rear seat Doh! Looks awesome Scott, hurry up and finish it so we can go play! Snow soon! Link to comment Share on other sites More sharing options...
czny Posted September 28, 2013 Share Posted September 28, 2013 (edited) How much vertical travel in the rear are you shooting for Scott? Looks to a be a great little wheeler! Edited September 28, 2013 by czny Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 28, 2013 Author Share Posted September 28, 2013 Doh! Looks awesome Scott, hurry up and finish it so we can go play! Snow soon! Im hurriun give me a couple weeks Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 28, 2013 Author Share Posted September 28, 2013 How much vertical travel in the rear are you shooting for Scott? Looks to a be a great little wheeler! whatever I can get, flex is more important back there for our terrain Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 29, 2013 Author Share Posted September 29, 2013 got the dual range trans all in with the adapter plate and redrilled EA82 flywheel Link to comment Share on other sites More sharing options...
Scott in Bellingham Posted September 29, 2013 Author Share Posted September 29, 2013 heres the old clutch this is why the car was parked a couple years ago rear setup 1 Link to comment Share on other sites More sharing options...
Uberoo Posted September 30, 2013 Share Posted September 30, 2013 Just curious is the EJ starter slightly shorter than the DR starter or am I seeing stuff? Link to comment Share on other sites More sharing options...
ryot1 Posted October 1, 2013 Share Posted October 1, 2013 LETS SEEEEEEE MORE!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Link to comment Share on other sites More sharing options...
