SJR Wheeler Build 90 Legacy Wagon 2013
Scott in Bellingham
looks like I may drive this Hog Tomorrow, today I tidied up the engine compartment, lengthened a heater hose, a gas hose, moved some wires around, moved the rad top forward 1/2", lengthened the steering knuckle,  mounted a 2000 Y pipe in, looks more like a U-pipe ,bought a rad hose, so looks like shifting linkage, driveline, rear track bar and its a driver, been just over a month so far, still got tons left to do , hope to hit the trails in a couple weeks
Edited by Scott in Bellingham
MO PICS
1185035_1452213578337539_1539176679_n.jp
1374122_1452214115004152_1261747379_n.jp
1379897_1452214075004156_1315373398_n.jp
stock 90 y pipe top, 2000 2.5 pipe on bottom, went with the 2000 as is shorter and Ill be mounting the exhaust
up high over the tranny crossmember and un against the body
1385159_1452214038337493_1105495926_n.jp
went to O Reilly's and found a hose that made  both top and lower  hose , they have literally  100s of hoses to choose from
1378534_1452213825004181_1347864764_n.jp
1375218_1452213718337525_1930437654_n.jp
1381440_1452213688337528_2000816145_n.jp
  On 10/12/2013 at 3:26 AM, monstaru said:
The problem is , not wanting to just step away from Subaru...LOL
Then at least you could have some real suspension. :)
cheers
I like the Subaru and hey its makin me a living, should hit the trail next weekend , still want to take a dualrange and add some real lower gears in the low range area, might take some welding and machine work with some added parts
  On 10/14/2013 at 3:19 AM, czny said:
Ah, I get it...the center is a trunion joint.
Correct?
It's a DOJ type CV.
Looks like a late 90's legacy driveline.  Some models have this type, others it's just a Ujoint.
My thought is that it won't have enough slip.  it's not a slip yoke.  When that axle starts going up and down that joint may not have enough travel.
Scott, look into Nissan and Izuzu drivelines.  Same input ends at the trans, and flange at the axle.  Get 2wd model one from nissan will have slip section in it.
