Natemanas Posted September 9, 2013 Share Posted September 9, 2013 Today I completed the timing belt replacement on my loyale. First time I've done this and lemme tell ya, Miles Fox's YouTube video was a huge help! Initially I did it to replace the timing gaskets on the cams, as they were leaking like a sieve, but wanted to do it right with a full timing belt service. The car is running night and day better than before... It's still leaking in other areas to address but that will come in time. Anyone have good info on replacing the rear seal? Thanks for all the support y'all! Link to comment Share on other sites More sharing options...
Natemanas Posted September 9, 2013 Author Share Posted September 9, 2013 Also, the distributor needs to be readjusted because The last owner just advanced it all the way to cope with the timing belt issue (skipped tooth I guess). We're should I set the dist to? Pics? Link to comment Share on other sites More sharing options...
987687 Posted September 9, 2013 Share Posted September 9, 2013 If it's an EFI model, the timing needs to be set to 20 DBTDC with the green connectors connected. Important, connect the green connectors while setting timing, more important, disconnect them afterwards. If it's a carb model.... No idea. Link to comment Share on other sites More sharing options...
Natemanas Posted September 9, 2013 Author Share Posted September 9, 2013 So I'll need a timing light for that or...? I'm used to Hondas so I'm very new to the ways of the h4 Link to comment Share on other sites More sharing options...
987687 Posted September 9, 2013 Share Posted September 9, 2013 You need a timing light. Hook it to plug wire #1, the front passenger side wire. Timing is basically the same on anything ever. You twist the disty until the light flashes on the mark. If yours is a manual, the timing mark is on the flywheel. Pull off the flywheel inspection cover (rubber thing) on the passenger side bell housing. If it's an automatic I know that the timing mark is on the crank pulley, but beyond that I'm not sure because I don't have an automatic. 1 Link to comment Share on other sites More sharing options...
Natemanas Posted September 16, 2013 Author Share Posted September 16, 2013 good deal, thanks! Link to comment Share on other sites More sharing options...
