pearlm30 Posted September 12, 2013 Share Posted September 12, 2013 MY 98 auto forester with drum brakes needed rear wheel bearings. The donor car is MY 99 with rear disc brakes. I know I def need e brake cable, but the donor is so rusty I am not sure i can pull everything I need off the donor. Do the rear brake calibers, hubs and rotors are the same from legacy/outback fit forester? And any other suggestion? Thanks a lot! Link to comment Share on other sites More sharing options...
MilesFox Posted September 12, 2013 Share Posted September 12, 2013 (edited) You can swap the backing plate, but you will have to get the hub out of the bearing to get anything apart. Edited September 12, 2013 by MilesFox Link to comment Share on other sites More sharing options...
bratman18 Posted September 12, 2013 Share Posted September 12, 2013 You just swap the entire rear knuckles with brakes and ebrake cable and abs cable attached. Link to comment Share on other sites More sharing options...
