tfrank36 Posted September 12, 2013 Share Posted September 12, 2013 (edited) 4eat trans pan NEED HELP!! Edited September 12, 2013 by tfrank36 1 Link to comment Share on other sites More sharing options...
tfrank36 Posted September 12, 2013 Author Share Posted September 12, 2013 I just had my tranny replaced in my 95 ej22 impreza. The next day I realized the seal around the pan was leaking. Also there's a blue paste around where the pan meets the tranny. It has been dripping from the back of the pan at the seal for about 5 hours. The atf dipstick is still showing full. Is this normal sense it was just put in and maybe the sealant had not cured? Link to comment Share on other sites More sharing options...
Rooster2 Posted September 12, 2013 Share Posted September 12, 2013 No, leaking ATF is never normal. Dropping the pan on a Subie always invites leaks. I found this out, wish I had never dropped the pan on my car. The blue paste is prolly Permetex sealer that is designed for sealing the pan. Best to take the car back to where the work was done, tell them the problem, and have them fix it. The shop should have removed all remnants of the old gasket, then used a new gasket, with just a little Permetex. Shame on the shop, if they tried using Permetex only, or reused the old gasket, instead of a new gasket. Ask the shop if a new gasket was used. Link to comment Share on other sites More sharing options...
