No point on the old 2.2. If the HG goes bad on that it will be a combustion chamber leak and no amount of coolant conditioner will stop that.
If you have the phase 2 with MLS gaskets it may be helpful, but even those are not prone to leaking.
Phase 2 2.5 is the one that needs the coolant conditioner because it seeps externally.
like said, it's only intended for later Phase II EJ25 engines (00+ and some 99's) with a very specific failure that they all have in nearly the same spots - external headgasket breach.  it's unlikely to do anything for the EJ22 which doesn't leak unless it's been overheated/run hot.
but for $2 a bottle from Subaru, who cares either way, you don't have anything to loose as long as it's properly used.
  On 9/16/2013 at 4:45 AM, igammie said:
I am in the process of replacing all the hoses, but that is about four a year....
I didn't know it would help with hoses
For the price I might try it?  There are no leaks, yet...
If you are making all good/new hose connections, you might just save the $2-$4 w'ever and skip it.
here's more info about it; http://www.scoobyenthusiast.com/subaru-maintenance/all-about-subaru-cooling-system-conditioner-soa635071
Edited by 1 Lucky Texan
  • Like 1
