HASx11 Posted September 16, 2013 Share Posted September 16, 2013 I bought a 1992 Subaru Legacy wagon this past week. When I bought the car I was told there was no issues with it. Four days after I got it I found that there was a gas leak coming from around the filler neck it is the metal part that goes into the tank it is rusted and there is a pin hole in it. I was wondering if this is part of the filler neck or its own piece. As I would like to get this fixed as soon as possible. Also I was wondering if I should get the timing belt done. The car has 192116 miles on it and the timing belt was done back at 116217 miles. If that needs to be is there anything else I should check? I know I need to get the water pump done when I do the timing belt but I wanted to make sure there are no future issues down the road besides general maintenance. Any help would be greatly appreciated. Thank you Link to comment Share on other sites More sharing options...
matt167 Posted September 16, 2013 Share Posted September 16, 2013 You have 75k miles on a belt most likely rated for 60k, so yes it should probably be changed. I think you can go for the 105k mile belt if one is available for it. Otherwise, change the belt and idlers. That engine is non interference so if it breaks, it's not a big deal except the tow. The fill neck is one complete part and $80 from the aftermarket. Common rust out due to a guard Subaru put up in there. Link to comment Share on other sites More sharing options...
MilesFox Posted September 16, 2013 Share Posted September 16, 2013 Depends on if the idlers were replaced with the timing belt. Usually the belt will last until a idler or WP seizes, taking the belt with it. Check the cam seals for oil contamination on th ebelt. Consider doing the cam seals. Link to comment Share on other sites More sharing options...
heartless Posted September 16, 2013 Share Posted September 16, 2013 Do all at the same time - timing belt, idler pulleys, water pump, cam & crank seals - pull oil pump, check screws on back, new o-ring on oil pump... Use Ultra Grey, or similar for sealing oil pump & water pump to block. Link to comment Share on other sites More sharing options...
HASx11 Posted September 17, 2013 Author Share Posted September 17, 2013 Thanks everyone I was thinking of doing all that. I'm not sure though whether it has a 105,000 one or a 60,000 one I'm probably going to do it very soon. I just replaced the alternator today as it siezed while I was in a busy intersection. I ended up having to get it towed and I was driving all over the place trying to find luckily there was one left up in Middletown but it was quite a drive out of my way. It's up and running now but I still have to fix the fuel leak that the guard caused. Link to comment Share on other sites More sharing options...
