mike300z Posted September 17, 2013 Share Posted September 17, 2013 Let me start this off by telling the story. I was driving my 88 subaru over to my dads garage to replace the rear wheel bearings which were past due, when the car lost most of its power and shut off. I pulled over on the side of the hwy where a friend came out with his buick Rivera and towed me to my dads. Further inspection showed the passenger cam gear broke!!!! Luckily I have a extra motor that is seized up and I took the cam gear off of that, I also had an extra set of new timing belts!! I re timed the motor the first time I was a tooth off and it ran but not right, In between that time and when I had it set right I turned it over with the coil disconnected from the distributor. I noticed the coil sent a spark out of it. Now when I moved the pulley over a tooth and try to start it there is no spark. I changed the coil still no spark, I also switched the distributor to another one I had not sure if its good or not, still no spark. My buddy said it could be the spark ignitor which seems to be located under the coil. can anyone help me here? Link to comment Share on other sites More sharing options...
86 Wonder Wedge Posted September 17, 2013 Share Posted September 17, 2013 Could be the ignitor, but I'd make sure you've got 12V at the coil KOEO. Also check the fusible links make sure none of them are popped. Link to comment Share on other sites More sharing options...
naru Posted September 17, 2013 Share Posted September 17, 2013 Could well be the coil bracket mounted ignitor.I`ve seen them damaged by disconnected coil high tension wires. If the injector(s) fire w/cranking,disty is OK. If injector works and coil negative has power,but still no spark,ignitor is likely fried. Link to comment Share on other sites More sharing options...
mike300z Posted September 23, 2013 Author Share Posted September 23, 2013 thanks for the tips, Will try this Wednesday Link to comment Share on other sites More sharing options...
mike300z Posted September 26, 2013 Author Share Posted September 26, 2013 Well I gave it a try, 12v at the coil. Cranked the car over and it didnt sound like the injector was firing, took off the air intake tube and cranked it, no gas on squirting in. so i guess its the distributor. Is there any way to test the distributor? I'm looking to buy a good one if anyone has an extra they could sell me Link to comment Share on other sites More sharing options...
ivans imports Posted September 26, 2013 Share Posted September 26, 2013 dis needs to be grounded also check all pins on conectors and on the wire harness side of conectors likes to break about 1/2 inch from conectors and is hard to see Link to comment Share on other sites More sharing options...
Cougar Posted September 26, 2013 Share Posted September 26, 2013 You checked for 12 volts on the plus side of the coil but did you also check for power on the minus side of the coil along with seeing if that connection makes pulses while cranking the engine. If the test light stays on steady while cranking the engine then the disty isn't sending ground pluses to the coil for some reason. You should also make sure no fuses are blown. Especially fuses 5, and 11. Link to comment Share on other sites More sharing options...
mike300z Posted September 26, 2013 Author Share Posted September 26, 2013 I did check both sides of the coil. did not try the test light yet, I did check all the fuses, I will re check them again. I thought someone mentioned grounding the coil bracket today, but its deleted now Link to comment Share on other sites More sharing options...
mike300z Posted October 1, 2013 Author Share Posted October 1, 2013 Ivans Imports pointed me in the right direction, Grounding out the coil bracket!! Link to comment Share on other sites More sharing options...
Cougar Posted October 1, 2013 Share Posted October 1, 2013 Thanks for the update. Link to comment Share on other sites More sharing options...
ivans imports Posted October 1, 2013 Share Posted October 1, 2013 Subaru # 233 fixed lol have been giving subarus #bers to keep better track of fix's Link to comment Share on other sites More sharing options...
