trouble with 97 subaru outback
recently my front U-joint went out on my car ended up cracking the transfer case, long story short i replaced all the parts had the car running fine, until i went to star it the next morning and couldn't get it to fire up. it cranks fine and sounds like normal just won't get the firing kick. anyone have any suggestions on what i can do to get it running again? i also tested the fuel pump but it seems to be working fine.
thanks,
Connor
i checked all the wiring and was able to get the car started, now it runs fine for about 5 seconds and then dies. i gave it constant gas the second time i started it which made it seem to run fine but as soon as i let off the accelerator, its bogs down and dies. i was also told this could be from a fuel pressure regulator or sensor going bad but still am not sure how to check or find these items.
