The if we see the same problem on more than 4 cars thread
ivans imports
Thought this might be a good diagnostic thread if any techs see same problem on the same type of car post it here. If i come axross the problem on more than 4 cars will post it .
This can be a good start Had 4   01- 03 outbacks five speeds all expanded center diffs. Fix was to install the awd center diff from 95-99 five speed. Is stronger awd unit. Heres one more had 4 97-99 imprezas with broken coged idler and bent valves fix 16 valves and coged idler /timing belt. Had 4 -8 99-03 outbacks with leading rear trailing arm front bushing hamered out fix press in new bushing. And so on the more imput the better
  • Like 1
Or the reverse shim on early five speeds to make reverse 70 % stronger i do every DR i biuld i get them made up 20 at a time. Heres a good one 03-09 2.5 turbos breaking the oil PU tube off and wiping out bottom end. One more 99-04 2.51s cly head droping ex valve giudes check all ex valve guide height. They sell a slightly biger guide that can be pressed in place of stock ones. And so on
  • Like 1
06 outback 2.53 engines leaking coolant thru headbolt into oil pan and coolant geting into oil unoticed and pcv pulls water out but leaves coolant deposits in oil riuning oil and damaging engines. Fix change headgaskets plane heads kms 145000 km 135000kms 160000kms 194000kms and 155000kms all fail very close to same milage all had leak thru headbolt bottom DS and PS top coner bolt
