Rebuilding rear caliper- tolerance to pitting on piston
Cheap-SOB question of the day...
I have a salvaged rear caliper I'd like to rebuild, it has some pitting, almost all of it beyond where the square sealing O-ring will need to sit or travel over, but with a little where I think it will need to go.
Is some pitting tolerable? It will polish to where it has no bumps.
Can you get pistons?
The bore is in good shape, the bleeder came out, if I end up not using it maybe someone out there can use the caliper if they have a decent pistion.
I might get really lucky and might only need one caliper, the one for which I have a replacement! I think only one of my rears is dragging.
