PA Grown Posted September 22, 2013 Share Posted September 22, 2013 So I have a subaru over here in CO came with some wide 28 inch tires. It's got an 84 brat transmission and I absolutely roast my clutch trying to climb really steep trails like aspen mountain 4x4 trails. I only have a 4-hi transmission. Trying to climb from time to time my car will stall out because my engine just can't turn the gears with the 28s. I'm stumped. Accept my subaru sucks on trails. Smaller tires and lift it(wheel wells are chopped for the tires). Different gear box. More hp? I'm not keen on a regear as I'm broke and 18. Link to comment Share on other sites More sharing options...
AdventureSubaru Posted September 22, 2013 Share Posted September 22, 2013 Find a good used dual range transmission and swap it in. These can be found cheap, especially if you are patient. All bolts right in. No difference between it and the single range. Link to comment Share on other sites More sharing options...
PA Grown Posted September 22, 2013 Author Share Posted September 22, 2013 I'd be switching from a 4spd brat to I'm assuming you mean a dual range gl transmission? It'll just bolt in? Link to comment Share on other sites More sharing options...
92_rugby_subie Posted September 22, 2013 Share Posted September 22, 2013 I believe there is a 4 speed dual range from the brats/hatches A 5 speed dual range swap is possible but requires some additional parts and modifications Link to comment Share on other sites More sharing options...
disom93 Posted September 22, 2013 Share Posted September 22, 2013 Can u do the swap if the starter is at top of the motor? I heard u couldnt?? Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted September 22, 2013 Share Posted September 22, 2013 Can u do the swap if the starter is at top of the motor? I heard u couldnt?? If the starter is on top, the motor isn't an 84 The last year for starter on top I believe was 81 or 82. After that all the EA71's were "fat case" and had the side/corner mounted starter. I haven't ever seen a dual range top mount tranny myself, but they may exist. Twitch Link to comment Share on other sites More sharing options...
PA Grown Posted September 22, 2013 Author Share Posted September 22, 2013 We'll I have an 84 brat tranny and it's definetily not the stock transmission. I believe the transfer case is innermarried to these older subaru transmissions. So I'd have to get a whole dual speed transmission. And this 4 SPD blows for my setup. I can't get my car going fast enough to use 4th. Granted I can do 70 in 3rd. I'm leaning towards a 5 SPD dual range. If I can find one! Link to comment Share on other sites More sharing options...
PA Grown Posted September 22, 2013 Author Share Posted September 22, 2013 What about just switching to a weber 32/36 carb? I heard it can boost hp from 70 to 100? Correct my numbers please. I have an old stock carb that's getting towards the end of its life. Link to comment Share on other sites More sharing options...
AdventureSubaru Posted September 22, 2013 Share Posted September 22, 2013 What about just switching to a weber 32/36 carb? I heard it can boost hp from 70 to 100? Correct my numbers please. I have an old stock carb that's getting towards the end of its life. Extra HP would be a short term solution for off roading. If you're hitting the clutch hard now, you'll only do more damage with more HP. A weber is a nice power upgrade but not a gearing solution turning 28s. That low gear will make all the difference for off road. If you get a 4 speed dual range from an EA81 car it will bolt right in - no modification necessary. Last tranny swap I did took maybe 6 hours total. They're a little heavy, but it's not a very difficult job, especially if you have a buddy to help. A 5 speed dual range requires an EA82 drive shaft, and modified shift levers and a few options between redrilled flywheel, EA82 clutch/flywheel or some such thing. I forget the specifics. Not a terrible job, but more involved than just bolting up the 4 speed dual range. The last two transmissions I purchased for cars of this generation cost me $100. and $65. Link to comment Share on other sites More sharing options...
PA Grown Posted September 22, 2013 Author Share Posted September 22, 2013 Yah I dig the 4 SPD brat tranny I've got besides the transfer case. So it's any 4spd from an ea81 with 4 hi-lo I want? Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted September 22, 2013 Share Posted September 22, 2013 Extra HP would be a short term solution for off roading. If you're hitting the clutch hard now, you'll only do more damage with more HP. A weber is a nice power upgrade but not a gearing solution turning 28s. That low gear will make all the difference for off road. If you get a 4 speed dual range from an EA81 car it will bolt right in - no modification necessary. Last tranny swap I did took maybe 6 hours total. They're a little heavy, but it's not a very difficult job, especially if you have a buddy to help. A 5 speed dual range requires an EA82 drive shaft, and modified shift levers and a few options between redrilled flywheel, EA82 clutch/flywheel or some such thing. I forget the specifics. Not a terrible job, but more involved than just bolting up the 4 speed dual range. The last two transmissions I purchased for cars of this generation cost me $100. and $65. No flywheel modification necessary for the 5sp aside from resurfacing it to the right clutch spec. Modifying shift levers is minimal, the biggest issue is the crossmember, and that only requires downspacing, and if you want to retain a chrome shift lever or not. Everything else is pretty straight forward for the swap. Just talk to Jerry (Bratsrus1) and he can hook you up with one of his kits. You just supply the transmission, clutch and the driveline (and the money to buy the kit of course ) Yah I dig the 4 SPD brat tranny I've got besides the transfer case. So it's any 4spd from an ea81 with 4 hi-lo I want? You can go that route, look for a low mileage one. I have killed 2 of those transmissions myself, 1st gear in one and 3rd in another. Find a low mileage one that has clean gear oil. That will be your clue to its life so far. Also, if you get the chance, check the magnetic drain plug. Lots of metal shavings, bad juju. Very few metal shavings, good news. No metal shavings, somebody flushed and changed the fluid and cleaned the drain plug. Who knows... Twitch Link to comment Share on other sites More sharing options...
Loyale 2.7 Turbo Posted September 22, 2013 Share Posted September 22, 2013 So I have a subaru over here in CO came with some wide 28 inch tires. It's got an 84 brat transmission and I absolutely roast my clutch trying to climb really steep trails like aspen mountain 4x4 trails. I only have a 4-hi transmission. Trying to climb from time to time my car will stall out because my engine just can't turn the gears with the 28s. I'm stumped. Accept my subaru sucks on trails. Smaller tires and lift it(wheel wells are chopped for the tires). Different gear box. More hp? I'm not keen on a regear as I'm broke and 18. How often you use it for mountain Trials? ... If you Also use it as daily Driver? In my Case, I chose 25" tires and 2" lift because my "Mixed" kind of Driving: 40% Offroading on Weekends + 60% of on road duty, 'cos is my Daily driver, Also I Placed a Weber Carb ... I don't have Dual Range, but my "BumbleBeast" goes Strong Everywhere with that Combo. Kind Regards. Link to comment Share on other sites More sharing options...
disom93 Posted September 22, 2013 Share Posted September 22, 2013 Not to hijack ur thread but can any of u tell me what i wpuld need to convert a 1980 brat top starter, 4speed single range to dual range? 4 or 5 speed it doesnt matter just need low Link to comment Share on other sites More sharing options...
rrgrr Posted September 22, 2013 Share Posted September 22, 2013 What about just switching to a weber 32/36 carb? I heard it can boost hp from 70 to 100? Correct my numbers please. I have an old stock carb that's getting towards the end of its life. I am seriously doubtful that Any carb swap as a single upgrade can make 30 hp -unless you are seriously starving the motor currently. If there was that much lost power, I believe Subaru would have done something different in the interest of efficiency. Link to comment Share on other sites More sharing options...
Twitch de la Brat Posted September 22, 2013 Share Posted September 22, 2013 We'll I have an 84 brat tranny and it's definetily not the stock transmission. I believe the transfer case is innermarried to these older subaru transmissions. So I'd have to get a whole dual speed transmission. And this 4 SPD blows for my setup. I can't get my car going fast enough to use 4th. Granted I can do 70 in 3rd. I'm leaning towards a 5 SPD dual range. If I can find one! While you're technically right about the transfer case being intermarried, there technically is no transfer case. Its just a gearset at the back of the transmission that locks the rear output shaft to the front. And the low range gearing actually engages before the power hits the rest of the transmission. That gearset is right up front in the transmission housing and its actually a totally different part from the 4 wheel drive. Disom93, that will require an engine swap to make it work, as the 'fat case' and 'slim case' EA bellhousings are incompatible. Twitch Link to comment Share on other sites More sharing options...
Uberoo Posted September 22, 2013 Share Posted September 22, 2013 so your starter is top mounted right? Link to comment Share on other sites More sharing options...
NorthWet Posted September 22, 2013 Share Posted September 22, 2013 If the starter is on top, the motor isn't an 84 The last year for starter on top I believe was 81 or 82. After that all the EA71's were "fat case" and had the side/corner mounted starter. I haven't ever seen a dual range top mount tranny myself, but they may exist. Twitch Much confusion added at this point, since someone other than the OP asked about top mount starter. So, to clear things up: PA Grown, is your starter on the side like an 84 Brat should be, or on the very top-center like a much earlier Brat? Link to comment Share on other sites More sharing options...
ivans imports Posted September 22, 2013 Share Posted September 22, 2013 2.5 with 4.44 4eat all the power and gears you will ever need or 5 speed DR and 2.2 works well to Link to comment Share on other sites More sharing options...
AdventureSubaru Posted September 22, 2013 Share Posted September 22, 2013 I'm not keen on a regear as I'm broke and 18. 2.5 and a 4.44 would be a great setup, but probably not fitting for an 18 year old on a budget. If you can post up a picture of where your starter is mounted, we can tell you concretely which transmissions to go for. Chances are that you have options for EA series transmissions. The quick and simple solution find a 4 speed dual range and swap it in - no modification necessary. The other option, which will probably be a bit more expensive and a little more labor intensive project - swap a 5 speed dual range with the added parts/modification. The 5 speed has better gearing, the 5th gear for highway driving and is less prone to failure than the earlier 4 speed. The 4 speed isn't a bad trans, just not as bullet proof as the later 5. PA Grown- what's your automotive experience so far? There are a lot of options available to your car, but if you're new to working on it/modifying it, best to start small and manageable. If we know what you're up for we can give better advice for your needs. Either way, go easy on that clutch until you've got something line up. Unless it's just a wheeler. Twitch - Isn't there a re-drilling option for the flywheel to keep an EA81 clutch? Or some such thing? It's been a while since I researched the particulars of it. I have a low miles 5 speed for the Ski Team Wagon, but the project is on hold for now until I get the car out here. Link to comment Share on other sites More sharing options...
PA Grown Posted September 22, 2013 Author Share Posted September 22, 2013 I have an 87 2dr gl With a ea82 ohv engine in mine. My starters near the drivers side behind the engine. Link to comment Share on other sites More sharing options...
PA Grown Posted September 22, 2013 Author Share Posted September 22, 2013 My current experience is apprenticing at woody creek speedway near aspen CO. So lots of mixed things experience with cars vs racers vs desert trucks. I helped swap one transmission in my life. But I can get help from one of the guys up at the track no problem. Link to comment Share on other sites More sharing options...
Gloyale Posted September 22, 2013 Share Posted September 22, 2013 (edited) If your trans is single range, it's not from an 84 brat. all manual trans second gen brats had 4spd dual range trans. Weber carb will not yeild 30 hp increase. I'm not convinced they add any power at all, just make it louder and "less cluttered" under the hood. I personally preffer the Hitachi carbs, and a few air bleed hoses don't scare me. Help us help you here and please tell us the year, model, and engine OF THE CAR! not what year you think the trans is from....not very helpful information. Edited September 22, 2013 by Gloyale 1 Link to comment Share on other sites More sharing options...
PA Grown Posted September 22, 2013 Author Share Posted September 22, 2013 We'll the reason me and the guys at the track think it's an 84 brat is those are the only axle we can get to fit the front end. Of course all the splines for these old subarus seem to be the same so far. This cars a junkyard dog I'm finding out new things about its history every other repair I make. Link to comment Share on other sites More sharing options...
PA Grown Posted September 22, 2013 Author Share Posted September 22, 2013 So what do you guys think then!? Do I have a 84 brat transmission with just hi 4wd? What am I working with here? Link to comment Share on other sites More sharing options...
capn_r Posted September 22, 2013 Share Posted September 22, 2013 (edited) What Gloyale said, Help us help you here and please tell us the year, model, and engine OF THE CAR! not what year you think the trans is from....not very helpful information. You still didn't say the year of the car. Maybe look in the door jam for a date code if you don't know? Edited September 22, 2013 by capn_r 1 Link to comment Share on other sites More sharing options...
