TRAVIS75 Posted September 25, 2013 Share Posted September 25, 2013 Looking like I need to replace the clutch on my 89gl d/r sub. That or it needs adjusted. Not sure. My question is, when I look it up on Napa Pro Link here at work it comes up with 2 different clutches, a 21 spline and a 24 spine, huge different in price. And though I've replaced one once before its been a few years and needless to say I don't remember. I called napa and had them look it up, and it was saying that one of the 2 was for an xt, I wouldn't think they would have the same clutch, but I don't know. And while I'm asking, what is the most popular method of changing the clutch. The one that I did, I just changed it because I was converting from push button 4x4 to dual range and figured it was as good as time as any to do it. However, seems to me possible doing it by removing engine would be easier. Thoughts? Link to comment Share on other sites More sharing options...
jono Posted September 25, 2013 Share Posted September 25, 2013 21 splines are more the EA81 clutch for both 200 and 225mm dia clutches. 24 spline ( measures 25.4mm OD ?) and 225mm dia clutches are your EA82 4WD clutch always about twice the price of above ! Link to comment Share on other sites More sharing options...
LeoneTurbo Posted September 26, 2013 Share Posted September 26, 2013 Removing the engine is way easier, at least for vehicles w/o a/c. Link to comment Share on other sites More sharing options...
ivans imports Posted September 26, 2013 Share Posted September 26, 2013 24 spline 8/7/8 i belive I pulled the trans on mine last week did clutch took me 2 hours on hoist with trans jack At same time i installed a reverse shim in trans and filed #1 #2 syncros so reverse is 70 % stronger and downshifts to 1rst and 2nd with no problems. Took 1 hour to go thru trans Link to comment Share on other sites More sharing options...
TRAVIS75 Posted September 26, 2013 Author Share Posted September 26, 2013 So the consensus then is that it should be a 24 spline, I checked at Oreilly's and all they came up with was that it was supposed to be a 21 spline, they didn't even have a listing for a 24 spline for my application. Link to comment Share on other sites More sharing options...
NorthWet Posted September 26, 2013 Share Posted September 26, 2013 Should be Orielly's Part # : KF680-02 Took me longer to specify your vehicle than to kind the proper clutch. Key might be either "4WD" or "8inch". Link to comment Share on other sites More sharing options...
TRAVIS75 Posted September 26, 2013 Author Share Posted September 26, 2013 Looking like I need to replace the clutch on my 89gl d/r sub. That or it needs adjusted. Not sure. My question is, when I look it up on Napa Pro Link here at work it comes up with 2 different clutches, a 21 spline and a 24 spine, huge different in price. And though I've replaced one once before its been a few years and needless to say I don't remember. I called napa and had them look it up, and it was saying that one of the 2 was for an xt, I wouldn't think they would have the same clutch, but I don't know. And while I'm asking, what is the most popular method of changing the clutch. The one that I did, I just changed it because I was converting from push button 4x4 to dual range and figured it was as good as time as any to do it. However, seems to me possible doing it by removing engine would be easier. Thoughts? Should be Orielly's Part # : KF680-02 Took me longer to specify your vehicle than to kind the proper clutch. Key might be either "4WD" or "8inch". I did put that it was d/r, but when I used Napa pro link, it never asked the size, just showed 2 spline counts, I called them, and from what they told me, the 21 spline is for fwd, 24 is for 4wd. Oreilly's gave me a number KF475-01, but it was a 21 spline, they didn't show a 24 option. I will just order an 8" 24 spline. Appreciate the input, thanks everybody Link to comment Share on other sites More sharing options...
Gloyale Posted September 26, 2013 Share Posted September 26, 2013 Removing the engine is way easier, at least for vehicles w/o a/c. I disagree. You can pull the trans in about an hour without having to remove PS pump, Alternator, AC, Etc.....not to mention drain the coolant and disconnecting battery and fuel lines spilling fuel. Pulling the trans the only fluid you may need to top off when done is the trans fluid. Although if you disconnect the rear of the driveline, and leave the driveline in the back of the trans while lowering it you won't even lose any of that. Link to comment Share on other sites More sharing options...
TRAVIS75 Posted September 27, 2013 Author Share Posted September 27, 2013 I am thinking I will do it the engine way this time, the engine I have in there in the last 2 weeks has started leaking about a quart every 6 days, you can sit and watch while it drips after driving it a few miles, its also developed a ping, even when driving on flat ground, no power when i'm at a higher elevation, have to put it in 4 low to pull the slightest grade in the mountains, no bueno with hunting season in a couple weeks. I picked up a spare motor here at work from another wrecking yard, to my surprise it looks like a recent rebuild, or somebody spent a lot of time cleaning it up and painting it grey, figure now is as good of time as any to swap it out. Could a plugged cat be part of the pinging and lack of power in higher elevations? Link to comment Share on other sites More sharing options...
