ea82 wont start
So last friday i had my car running and it died when it ran out of gas and now it wont start. The timeing is on belts are good i pulled the plugs cleaned them checked the gap and made shure i had spark. Also checked and it is getting fuel so i dont know what to do plus i have a good combo switch and good fuse amd blinkers dont work please i need help soon or im gonna have to sell it
Spray some starting fluid into the intake and see if that gets some engine fire going. If that doesn't work then you need to check spark through the plugs. If that is okay then you need to check the compression.
For the blinker problem try cycling the emergency flasher switch a number of times to see if that makes the blinkers work. If that doesn't work then you need to start checking power through the circuit with a tester.
