nakedandfam0us Posted October 1, 2013 Share Posted October 1, 2013 Tearing down a 2002 ej251 to drop into a 2000 outback and noticed the L rear cam seal doesn't appear to be seated properly. There isn't evidence of a huge leak but I'd like to fix properly. Tap it square with a socket? Replace? What do you think. thanks! Link to comment Share on other sites More sharing options...
Fairtax4me Posted October 1, 2013 Share Posted October 1, 2013 Not sure I would bother with it as they don't generally leak. But they're only like $4 at the dealer so if you do anything with it just replace it. Trying to reseat it may damage it and make it leak. Link to comment Share on other sites More sharing options...
johnceggleston Posted October 2, 2013 Share Posted October 2, 2013 (edited) that does not qualify as a leak in my book. leave it. lots of other stuff will give you problems before that does. besides, it could be the valve cover gasket, maybe. Edited October 2, 2013 by johnceggleston Link to comment Share on other sites More sharing options...
idosubaru Posted October 2, 2013 Share Posted October 2, 2013 i don't notice anything wrong, those don't ever really fail or pose issues. i don't recalling ever seeing it personally or on the forum. that seal was recently mentioned like last week by a guy wanting to pull it so he can see if he can install a distributor at that point - that thread has some responses on replacing that seal. otherwise it's not ever done...it's more of a plug than a seal maybe? there's no rotating part passing through it. doubtful it will ever leak, yours would be like the first. 1 Link to comment Share on other sites More sharing options...
nakedandfam0us Posted October 2, 2013 Author Share Posted October 2, 2013 Thanks. I'll probably just leave the bugger as it is then. Link to comment Share on other sites More sharing options...
