86 rx springs
on my rx the kid i got it from cut the springs woul it sit higher if i put springs from a wagon on it i dont want a lift kit but i saw some pics of a stock 4 door rx and it sits pretty high and thats what i am looking for just like this rx turbo
I have fitted wagon springs to my 4WD sedan GLTA and sat about 25mm higher measured at rear bumper, felt very unstable and bounced around a lot with little load.The factory RX springs are 10.9mm thick wire, painted black and have one yelow paint daub on them as an identifier. FWD sedans use 9.9mm wire ?? Also be aware of the three or so different spring perch heights from the lower bolt hole. Affects all sort of things when swap about
