99 legacy 2.2 would be a phase2 as you stated. You can tell it's an ej22 because it's stamped into the block under the alternator.
You can tell it's a phase2 because the spark plugs go through the valve covers, as opposed to the funky shaped valve covers on a phase1.
It will swap into any 99-04 car that came with either a 2.2 or a 2.5 sohc if you put the right intake manifold and cam/crank gears on it.
Phase2 land is fairly plug and play lego game.
Edited by 987687
