RedBrat Posted October 8, 2013 Share Posted October 8, 2013 Getting ready to install the seats. I have done some searching and understand that the bracket that holds the bottom of the head restrant bar is absent from my Brat. Does anyone have a set (or one) of the brackets available. If not, can someone point me to a drawing or picture of the bracket. Seat location: obviously they need to be centered left to right, but can someone give me a dimenstion to locate the seats front to back. How many inches from the front wall to what part of the seat frame? Seat belt attachment: same questions. I am about 100 miles from my Brat so I will not be able to go look at it until the middle of next week. Anything else I should know? Thank you, 1 Link to comment Share on other sites More sharing options...
skishop69 Posted October 10, 2013 Share Posted October 10, 2013 The 87's did not come with seats, so the lower headrest bracket is not there. You would have to weld one (2) in. Also, the seats are welded in as well. Bolting them in is not a good idea unless you reinforce the tubing of the frame. It is thin walled and will buckle while tightening and most likely buckle or break with people in the seats if there were ever to be an accident. If bolting in, I recommend 4 pieces of 1/4" plate drilled and tapped to the appropriate bolt size then tack welded to the underside of the bed in the appropriate places. Reinforce the tubing with angle iron to form a half box over the top of the section you are going to run the bolt through. That's what I did when I put seats back in my '84. Link to comment Share on other sites More sharing options...
RedBrat Posted October 10, 2013 Author Share Posted October 10, 2013 The 87's did not come with seats, so the lower headrest bracket is not there. You would have to weld one (2) in. Also, the seats are welded in as well. Bolting them in is not a good idea unless you reinforce the tubing of the frame. It is thin walled and will buckle while tightening and most likely buckle or break with people in the seats if there were ever to be an accident. If bolting in, I recommend 4 pieces of 1/4" plate drilled and tapped to the appropriate bolt size then tack welded to the underside of the bed in the appropriate places. Reinforce the tubing with angle iron to form a half box over the top of the section you are going to run the bolt through. That's what I did when I put seats back in my '84. Thank you for the recommendations. At present I am planning on attaching them in six places to the bed. I will be welding the six "feet" that remained on my seat frames to plates and then the plates will be welded to the bed of the Brat. It will be as strong as the original installation. But I still don't know how far from or close to the rear wall of the bed to place them. Link to comment Share on other sites More sharing options...
jmoss5723 Posted October 10, 2013 Share Posted October 10, 2013 I'm also curious about forward/backward placement. I am putting seats back in my 84 and I'm not certain where they should go. Link to comment Share on other sites More sharing options...
greg454 Posted October 11, 2013 Share Posted October 11, 2013 On mine the top of the seat is 3 1/2" from the back window. The center of the seat bottom is 15" from the side of the bed. Link to comment Share on other sites More sharing options...
RedBrat Posted October 11, 2013 Author Share Posted October 11, 2013 On mine the top of the seat is 3 1/2" from the back window. The center of the seat bottom is 15" from the side of the bed. Just the information I needed, Thank you very much! Link to comment Share on other sites More sharing options...
jmoss5723 Posted October 11, 2013 Share Posted October 11, 2013 Greg, is that the stock location for the seats? Just curious whether you reinstalled seats and that's what looked good to you, or if they were still in the factory position. Link to comment Share on other sites More sharing options...
greg454 Posted October 11, 2013 Share Posted October 11, 2013 Greg, is that the stock location for the seats? Just curious whether you reinstalled seats and that's what looked good to you, or if they were still in the factory position. This is the stock location for the seats with the factory seat mounts. Link to comment Share on other sites More sharing options...
jmoss5723 Posted October 11, 2013 Share Posted October 11, 2013 That's exactly what I was hoping for. Perfect! Link to comment Share on other sites More sharing options...
skishop69 Posted October 12, 2013 Share Posted October 12, 2013 Yeah, the only reason I bolted mine in is that we use it for camping. I tow it behind the camper and we use it for bombing around with the kids/friends and hauling firewood so I wanted to be able to remove the seats in short order and put them back. Link to comment Share on other sites More sharing options...
RedBrat Posted October 15, 2013 Author Share Posted October 15, 2013 Now I need the location of the seat belt bolts. If someone can measure from the wall and from the front of the bed to the center of the bolt hole on one side and then the spacing across to each of the other bolt locations it would be great. I can then properly locate the belts in the stock locations. Prefer to not be guessing. Thank you, Link to comment Share on other sites More sharing options...
jonas Posted October 16, 2013 Share Posted October 16, 2013 If no one gets back to you on this i'll be able to measure mine this weekend. Link to comment Share on other sites More sharing options...
RedBrat Posted October 16, 2013 Author Share Posted October 16, 2013 If no one gets back to you on this i'll be able to measure mine this weekend. Thanks, Link to comment Share on other sites More sharing options...
jonas Posted October 16, 2013 Share Posted October 16, 2013 I have a bed mounted tool box covering the bolt holes i have to remove or i would have those measurments sooner..... Link to comment Share on other sites More sharing options...
greg454 Posted October 16, 2013 Share Posted October 16, 2013 (edited) The seat belt mounting bolt is: 4-3/8" from cab wall 5-3/8" from side bed wall (these are to bolt centers) same on both sides Hope that helps Greg Edited October 16, 2013 by greg454 Link to comment Share on other sites More sharing options...
RedBrat Posted October 17, 2013 Author Share Posted October 17, 2013 The seat belt mounting bolt is: 4-3/8" from cab wall 5-3/8" from side bed wall (these are to bolt centers) same on both sides Hope that helps Greg Yes, that helps alot. That locates the outside seat belts. How far from that anchor to the one for the inside belt? thanks, Link to comment Share on other sites More sharing options...
greg454 Posted October 17, 2013 Share Posted October 17, 2013 "Yes, that helps alot. That locates the outside seat belts. How far from that anchor to the one for the inside belt? thanks," Ooops......Forgot about about the inside belts. I'll look tonight. Link to comment Share on other sites More sharing options...
DaBrizat Posted October 17, 2013 Share Posted October 17, 2013 I have an extra frame for the seats. The frame was welded to the bed, and the stock seats bolted to it. You're welcome to it for the price of shipping. Send me a PM if you're interested. Link to comment Share on other sites More sharing options...
RedBrat Posted October 17, 2013 Author Share Posted October 17, 2013 I have an extra frame for the seats. The frame was welded to the bed, and the stock seats bolted to it. You're welcome to it for the price of shipping. Send me a PM if you're interested. I don't have an interest, but I would recommend posting its availability in the For Sale section as that is where people look to see what is available. There was a person that was looking for just the frame and was willing to pay freight not too long ago. Link to comment Share on other sites More sharing options...
greg454 Posted October 17, 2013 Share Posted October 17, 2013 OK more measurements Inner seat belt bolt holes are 2-1/2" from cab 23-1/2" from either side to center of bolts That should be all of them now....... Greg Link to comment Share on other sites More sharing options...
RedBrat Posted October 18, 2013 Author Share Posted October 18, 2013 OK more measurements Inner seat belt bolt holes are 2-1/2" from cab 23-1/2" from either side to center of bolts That should be all of them now....... Greg Greg, Thanks a lot! That is all the measurements that I need. It is good to get those numbers on the board as I expect there are others that can also use the information. Again, thanks a lot! Link to comment Share on other sites More sharing options...
RedBrat Posted October 18, 2013 Author Share Posted October 18, 2013 Ok, I just now thought of another question that I probably should have thought of earlier but didn't. When installing the seat belts, do the rollup ones go on the outside next to the bed walls or the inside or are they always on the passenger's left or right? Link to comment Share on other sites More sharing options...
TomRhere Posted October 18, 2013 Share Posted October 18, 2013 Retractable ones mount to the outside of the seats. Thinking there is a "R" and "L" stamped on them. Link to comment Share on other sites More sharing options...
RedBrat Posted October 18, 2013 Author Share Posted October 18, 2013 Retractable ones mount to the outside of the seats. Thinking there is a "R" and "L" stamped on them. Thanks, You've answered what is hopefully my last question on this subject. Link to comment Share on other sites More sharing options...
greg454 Posted October 19, 2013 Share Posted October 19, 2013 Since there seems to be some interest in this topic I went out and shot a few pictures of the jump seats today that show more mounting detail. Seats Belts And while I'm here just some pictures of my Brat Link to comment Share on other sites More sharing options...
