RustyBrat Posted December 11, 2013 Author Share Posted December 11, 2013 tomorrow i will give a pic update! Quote Link to comment Share on other sites More sharing options...
Bantum Posted December 11, 2013 Share Posted December 11, 2013 (edited) Okay ive got the lift kit and hardware ready to go on, but im confused on one piece. Where does this go ? Not sure, but it could be off the transmission ? Alternatively the front engine cross member mounts - Do the holes line up with anything ? ... Cheers, Bantum ... Edited December 11, 2013 by Bantum Quote Link to comment Share on other sites More sharing options...
RustyBrat Posted December 11, 2013 Author Share Posted December 11, 2013 Thanks for the reply! But i figured it out. Its for that little eye bolt thing that comes off the top of the bell housing Quote Link to comment Share on other sites More sharing options...
Bantum Posted December 11, 2013 Share Posted December 11, 2013 Yep - that's what I was thinking too ! ( 'engine stay' I think its called ) Ciao, Bantum ... 1 Quote Link to comment Share on other sites More sharing options...
SmashedGlass Posted December 11, 2013 Share Posted December 11, 2013 Pitch rod. Quote Link to comment Share on other sites More sharing options...
RustyBrat Posted December 11, 2013 Author Share Posted December 11, 2013 Pitch rod! Okay! Quote Link to comment Share on other sites More sharing options...
RustyBrat Posted December 12, 2013 Author Share Posted December 12, 2013 okay so im having a problem. i need to take the struts off, how the heck do i do that! the top is super easy of course, but the bottom i cant figure out. i took out all the bolts and still it wont come out, i dont understand... somebody help! Quote Link to comment Share on other sites More sharing options...
SmashedGlass Posted December 12, 2013 Share Posted December 12, 2013 Well, I'm sure someone with more knowledge of the older Subes will chime in, but until then.....if your struts are like the 3rd gen, after the pinch bolt holding the strut body to the hub is removed, you're gonna need to whack the spoob out the hub to get it to pop free of the strut. Or if you're lucky, just stand on the hub with a bar and it'll pop. Quote Link to comment Share on other sites More sharing options...
RustyBrat Posted December 12, 2013 Author Share Posted December 12, 2013 spoob? Quote Link to comment Share on other sites More sharing options...
Kevint143 Posted December 12, 2013 Share Posted December 12, 2013 Yea once you take the pinch bolt off and the back bolt that lines it up you make need to put a screwdriver in to wedge the strut out of the hub. If you have another sets of hands it may help. Quote Link to comment Share on other sites More sharing options...
RustyBrat Posted December 12, 2013 Author Share Posted December 12, 2013 alright, thats the mission for tomorrow. i cant seem to get the strut hats on, so im thinking this will make it easier Quote Link to comment Share on other sites More sharing options...
RustyBrat Posted December 13, 2013 Author Share Posted December 13, 2013 (edited) The front is lifted! Man that was difficult haha! The front crossmember blocks were easy, bolted right up, the rear crossmember blocks were different though, i had to drill them out bigger to accomodate the bolts. No big deal, until i got to the strut hats. First, i had to cut and grind them down to fit. Then i had to widen the holes with the milling machine. I ended up taking both the struts completely out and forcing the hats on, then putting the struts back in. Had to beat the struts out with a hammer! Camber is off, but im not worried about that right now, i'll fix it later. Edited January 10, 2014 by RustyBrat Quote Link to comment Share on other sites More sharing options...
Kevint143 Posted December 13, 2013 Share Posted December 13, 2013 a hammer has been my best tool login it man! you on Facebook? if so look me up https://www.facebook.com/kevint143 Quote Link to comment Share on other sites More sharing options...
RustyBrat Posted December 13, 2013 Author Share Posted December 13, 2013 gonna get the rear lift done by the 20th i hope, along with the steering extension and the shifters, that way i can take my grandpa out for a ride when he comes up for christmas and show him how far its come! (this was his brat that he gave to me) cant really figure out how to make these shifters work, i want to cut and weld so they fit through the holes in the trans tunnel, but they are stinkin aluminum! so i think im just going to build new ones. 1 Quote Link to comment Share on other sites More sharing options...
92loyale59 Posted December 13, 2013 Share Posted December 13, 2013 im not sure but it looks like you put the lift blocks for the front in wrong . like the left on the right side and the right on the left side. That may be why you have so much camber. just my thoughts . looks sweet lifted though nice work Quote Link to comment Share on other sites More sharing options...
RustyBrat Posted December 13, 2013 Author Share Posted December 13, 2013 Yeah i realized that before i put the struts back in, luckily the tops just spin around so i didnt have to switch them. That picture actually makes the camber look worse than it really is, its like 4 degrees off, no big deal. Thank you! It sits a lot higher than i imagined! Quote Link to comment Share on other sites More sharing options...
RustyBrat Posted December 14, 2013 Author Share Posted December 14, 2013 (edited) Built a steering extension today! Im pretty proud of it Edited October 24, 2015 by RustyBrat 2 Quote Link to comment Share on other sites More sharing options...
RustyBrat Posted December 14, 2013 Author Share Posted December 14, 2013 (edited) Got the rear of the brat up on jackstands its all ready to go, got everything soaking in pb blaster. Got one bolt out, then broke my ratchet! So that put a stop to my work for now. Edited January 10, 2014 by RustyBrat Quote Link to comment Share on other sites More sharing options...
RustyBrat Posted December 18, 2013 Author Share Posted December 18, 2013 okay quick question guys, what tire size should i buy for this thing? im thinking 205-70r15s right now but im afraid they will look too small, what do you guys think? Quote Link to comment Share on other sites More sharing options...
Kevint143 Posted December 19, 2013 Share Posted December 19, 2013 20s throw some Spinners on that beezy Quote Link to comment Share on other sites More sharing options...
RustyBrat Posted December 19, 2013 Author Share Posted December 19, 2013 HAH! no thank you 1 Quote Link to comment Share on other sites More sharing options...
RustyBrat Posted December 20, 2013 Author Share Posted December 20, 2013 ive got a chance to buy an ej25 with the matching transmission and rear differential for 300 bucks... i want to build the ej25 and then swap it into the brat! i know it will take major mods but im up for it, what do you guys think? Quote Link to comment Share on other sites More sharing options...
BratRod Posted December 20, 2013 Share Posted December 20, 2013 Buy it. Even if you don't use it, you can resell it. That's a killer price. Quote Link to comment Share on other sites More sharing options...
RustyBrat Posted December 20, 2013 Author Share Posted December 20, 2013 Well the ej25 needs its heads rebuilt... Still worth it? Quote Link to comment Share on other sites More sharing options...
BratRod Posted December 20, 2013 Share Posted December 20, 2013 You would want 2.2 heads anyway. They need to be SOHC to fit in the brat. Quote Link to comment Share on other sites More sharing options...
