95 Legacy - main fan runs all the time
It runs all the time if the battery is connected.   Fuse was burned when I got it, so it didn't work thru that circuit.  I put a fuse in it and its running continuously.  Car had alternator overcharge so I'm thinking it probably melted the bat. and switched power together on one of the relays.  Replaced alternator, fusible link, combination switch, and other electrical odds and ends.  Had no issues for months until I discovered the fuse.
So I'm looking way up under the dash, above the fuse block, for the fan relays???  Or am I on the wrong track??  Thanks.
