zachariah Posted October 10, 2013 Share Posted October 10, 2013 so about 4 months ago I changed the timing belt on my ea82. it was my first time doing so on this car and after failing and haveing a face palm moment. I watched miles fox's videos and did it right. now about 2 weeks ago I go to start my car before work and nada battery's dead. get a new battery after work and try again it acted like is broke a timing belt again so I look, and the damn thing had seperated so I go get a it replaced at napa they say they had never seen that before. put the new one on and button everything up and start it and it ran like an off balance washing machine. and the oil pressure shot to the top of the gauge. what do I do ? what's wrong? Link to comment Share on other sites More sharing options...
86 Wonder Wedge Posted October 11, 2013 Share Posted October 11, 2013 For the oil pressure, did you check the connection back at the pressure sender? I forget that thing all the time... And when you redid that belt, you used the 3 hash marks, not the timing/TDC marks, yes? Link to comment Share on other sites More sharing options...
zachariah Posted October 11, 2013 Author Share Posted October 11, 2013 never messed with the pressure sender and yep did the 3 hash's not the numbers put the driver side on first then rotated crank 360 and lined up the passenger. Link to comment Share on other sites More sharing options...
scoobiedubie Posted October 11, 2013 Share Posted October 11, 2013 Spark plug wires may be mixed up. Link to comment Share on other sites More sharing options...
Skylar Posted October 11, 2013 Share Posted October 11, 2013 never messed with the pressure sender and yep did the 3 hash's not the numbers put the driver side on first then rotated crank 360 and lined up the passenger. If you put the drivers belt on & rotated the motor 360° you rotated it too much. Take the belt of the cam pulleys, line the cams up, put the driver belt on, rotate 180° then put the passenger belt on, & rotate the motor until you see the 0 mark on the flywheel. Tighten your belts up & you should be solid. Link to comment Share on other sites More sharing options...
MilesFox Posted October 11, 2013 Share Posted October 11, 2013 If you put the drivers belt on & rotated the motor 360° you rotated it too much. Take the belt of the cam pulleys, line the cams up, put the driver belt on, rotate 180° then put the passenger belt on, & rotate the motor until you see the 0 mark on the flywheel. Tighten your belts up & you should be solid. This is false. Dude has it right by his description. I see how you mean there, but one cam is loaded if you put them out of phase and install both simultaneously. The video/procedure has you do them one at a time so the am is not pre loaded and slip from spring tension. I would rule out the timing is wrong, but i would rule in the spark plug wires may be mixed. rotation is ocunterclockwise, 1-3-2-4 cylinder arrangement when looking at the motor from the front of the car: 3 4 1 2 Link to comment Share on other sites More sharing options...
zachariah Posted October 11, 2013 Author Share Posted October 11, 2013 yeah that's how I did it the first time I replaced them Miles and drove for 4 months just fine. so I know I did the sequence correctly even watched ur video again to be sure. I'll check wires tomorrow. also the driver can was super hard to turn more than when I originally had done the job even with the pin tool it did not want to turn easily unlike the passenger can Link to comment Share on other sites More sharing options...
scoobiedubie Posted October 11, 2013 Share Posted October 11, 2013 Napa has some really cheap timing belts and some good timing belts. The cheap ones do not last long, as I understand. Napa also does not necessarily rebuild everything that they claim is rebuilt. If they take it in as a core deposit and it seems to work OK, they may just clean it, paint it and put it back on the shelves. Link to comment Share on other sites More sharing options...
zachariah Posted October 11, 2013 Author Share Posted October 11, 2013 yeah I bought the kit with the pulley and tensioners. when I took just the belt it they gave me just a belt obliviously and it seemed Better Link to comment Share on other sites More sharing options...
rdweninger Posted October 11, 2013 Share Posted October 11, 2013 There are 2 belt tensioners and a cogged idler on the ea82. Make sure you replace all 3 when you replace your timing belts. Imagine if the bearings 'freeze' up on any of those tensioners or idler.... Your timing belt won't last very long. Not too tight on the belt tension. Lose the plastic covers... so you can see what's going on... and quickly replace the 'next' set of timing belts. Hope this helps. Link to comment Share on other sites More sharing options...
zachariah Posted October 11, 2013 Author Share Posted October 11, 2013 yeah when I did it originally 4 months ago I replaced all those yeah I lost the belt covers when the water pump went Link to comment Share on other sites More sharing options...
zachariah Posted November 1, 2013 Author Share Posted November 1, 2013 figured out the geiser of oil was coming from the oil filter not the dip stick. changed the filter and new oil still the oil pressure rockets to 85 when I start the car any ideas? Link to comment Share on other sites More sharing options...
yblocker Posted November 2, 2013 Share Posted November 2, 2013 What does it read when hot? If it's over 60 psi at 3,000 rpm when hot, then try replacing the pressure switch on the oil pump. Easy to try. Mine did the 85 to 60 psi thing until i changed out the sender. Link to comment Share on other sites More sharing options...
Dee2 Posted November 2, 2013 Share Posted November 2, 2013 figured out the geiser of oil was coming from the oil filter not the dip stick. changed the filter and new oil still the oil pressure rockets to 85 when I start the car any ideas? probably the oil pressure sending unit is out, easy replacement, and not much money. Link to comment Share on other sites More sharing options...
zachariah Posted November 2, 2013 Author Share Posted November 2, 2013 i timed it again and doubled checked it all. still has no power too so idk if it is the sending unit Link to comment Share on other sites More sharing options...
