My NEW gen.... 2004 FXT..... ;-)
obk25xt
Been looking at these for a WHILE and really never thought I'd get my hands on one... I guess I'll start a thread, because I'm sure over time this thing WILL get meddled with haha.... I'm no noob to soobs OR building cars. Heres a link to my Loyale build thread for an idea of how I like 'em. FINALLY!! found the one I've been looking for. - Members Rides - Ultimate Subaru Message Board
For starters. Its a 2004, 5mt, 129,000 miles, bought it at a dealership in Bellevue WA for $7000. They had it advertised for $8900, I called on it cuz I've been looking for one and have been more serious lately. The salesman took my info and I scheduled a time to go look at it. He called me shortly after, said it went thru their shop, and that they couldn't sell it because it didn't pass the mechanical inspection. He said it had a weak clutch, leaky turbo, and smelled like burning oil. I said I didn't care and was still interested. After a lil haggling we settled on the price and I drove it home a few days later. Turns out the car is already on stock WRX springs/struts and has an STI catback.
I put a new Exedy clutch kit, an ACT streetlight FW (bought off a forum for $100 shipped), new front rotors, a full Gates timing kit, new NGK spark plugs, an OEM 06 STI up-pipe, a de-catted 3" SS down pipe (CL score for $25!), and replaced the pass side valve cover seal (the "leaky turbo" haha). I also put 06 STI springs on the front struts which brought the front down a lil more to cure the saggy-butt and give it the rake I like.
Throwing a dart I think I'm into it a total of around $8400 which includes tax/license and all the parts I bought, I installed them myself cuz I'm good like that.....
I intend to address the handling more than anything else, remove x-member spacers, RSB, lateral links, strut tower bars and possibly STI control arms. I'd like to put a VF series turbo, injectors, and a larger top mount too at some point, but for a while it will just be the exhaust and a tune.
Heres a pic
Looking good!
Next mod needs to be painting or plasti-dipping that C-pillar black. That was one of the first things I did to mine and it helps to give a continuous look along the length of the vehicle.
That random gray chunk just looks out of place.
  • 2 weeks later...
Looking good!
The c-pillar matches the mirrors, and the rear gate garnish, I'm gonna leave it as it is.... Soon it will match the wheels....
Edited by obk25xt
So I've done some things.....
Now its got:
Stop sign skid plate!
17x8 wheels with 225/50 tires
STI front springs on WRX struts
STI rear springs/struts
STI 20mm rear sway bar, whiteline bushings, and home made LLWS and heim endlinks
STI catback exhaust (what I thought WAS on it, now IS on it)
And a fresh alignment
PICS......
I guess I forgot that I color matched my mirrors and that they used to be that gray color.
I like your Stop sign plate. I used a "Slow Children Playing" sign for the same. Before I installed it though, a friend make a great suggestion to put it reflective side up. Now when I put a light into my engine bay, the highly reflective surface adds nice illumination. The downside to doing it that way is you lose "the look" of the sign under there.
  • 1 month later...
OK so lets recap……
Bought the car @ 130,000 miles….
Now has 133,000 miles…..
Things I've done….
ACT Streetlight FW
New Exedy clutch
New valve cover seal
New NGK spark plugs
New Gates T-belt kit
New rotors
New radiator
DIY stop sign skid plate
17x8 ROTA's
New Yokohama's 225/50/17
STI rear sway bar/mounts and DIY LLWS
STI up pipe
STI catback
COBB catted DP
Accessport
Group N trans mount….
And now…..
New PCV
VF39
STI TMIC
Grimmspeed AOS
This thing is coming along NICELY!!
Parts I HAVE and yet to install:
New oil cooler O-ring
WRX trans mount
Kartboy trans mount bushings
WRX pitchstop
WRX 5mt linkage
WRX driveline
WRX steering joint
Group N engine mounts
Wish list:
Short shifter/bushings
WRX rear subframe
STI lateral links
STI aluminum control arms
STI steering rack
Pics of VF39 install
Edited by obk25xt
  • Like 1
The VF39 definitely wakes these up. Man I miss mine.
Yeah like WOW!! Just running the COBB OTS map for it, which claims 285hp/323tq @ the wheels…. I wanna get a pro tune… 300 whp just seems like a good # lol…...
As-is it breaks traction in 2nd…. Def badass…...
I know, it's fun as hell. Any plans for a 6 speed swap? I loved that in mine as well.
  • 3 weeks later...
Got tuned today! I guess I'm satisfied I dunno?! 284whp 309 wtq, @ 17lbs. Was HOPING for 300whp, but I am def not upset…… With injectors, TGV deletes, and a turbo inlet I think 300 is doable…. By summer……
Blah blah blah pics….. Looks good?
  • Like 1
  • 3 weeks later...
Update…
Yesterday I removed the spacers from the engine crossmember, along with swapping the trans crossmember, driveline, pitch stopper, shift linkage and steering knuckle all from a WRX. The shift linkage I got was actually the SPT short shifter assembly, score! I also installed Prothane shifter bushings and Kartboy trans mount bushings. I am still using the stock splitter, I removed the rubber from it and trimmed about 3/8" from the front-most part of the duct so it doesn't interfere with the TMIC.
First impressions:
Shifter/bushings is a HUGE improvement, super stoked about that. Ground clearance is also a huge bonus, everything is tucked much better now.
Handles much flatter if that makes sense, feels more responsive, and doesn't lift/dive like it did before. It still does a little bit, but it's reduced and is noticeable. Overall the difference is subtle, but definitely an improvement.
Next on the list is the rear subframe and lockdown bolts. I need to gather a few more parts before I jump into that still though. I'm thinking about doing the diff hanger too and doing all the bushings while I'm in there too. I already have the rear diff hanger bushings may as well do the outrigger bushings too, which means the diff support etc. And I'm seriously contemplating getting some STI lateral links…. We'll see….
  • 6 months later...
  • 2 months later...
Ok so I'm ALMOST done hahaha.... Really tho.....
FEAL struts came in, and I paired them up with some JDM STI pinks. The ride is awesome. I think the car finally can out-handle my swapped loyale. I have an appt to get aligned on wed, and then I'm really not gonna mess with stuff for a while. I have some home made 3/8" spacers in the rear right now, but I'm gonna swap them out for some 1/2" spacers this week. It sits flat/level, but I would rather be prepped for hauling stuff. The lil extra fender clearance will make a difference. The ride with this setup is stiff but not harsh. I'm stoked......
So almost exactly a year later and here's the current parts list unless I forget something.
Power:
I did all the maintenance/repair needed from purchase, valve cover seal, full timing kit, new radiator, new PCV, spark plugs, and a new exedy clutch kit.
ACT streetlight FW
STI up-pipe
VF39
STI TMIC
GS AOS
GS EBCS
Walbro 255
K&N panel filter
COBB catted downpipe and AVO 3" catback
Tuned by PRE @ 17lbs, 284whp/309wtq
Handling:
Removed subframe spacers
WRX rear crossmember
WRX driveline
WRX SPT short shifter assembly
Group-N trans mount
Kartboy subframe lockdown bolts
STI spec-c control arms and lateral links
TIC rear diff bushings
Whiteline 24mm sways/bushings F/R
Kartboy endlinks F/R
FEAL revalved 5x100 STI struts
JDM STI pink springs
Brembos F/R
Goodrich SS brake lines
DBA 4000 rotors F/R
Hawk HPS pads
Rota G-Force 18x9 +35
Continental Control Contact 245/40/18
Others:
SG9 stereo with aux input
02-03 STI CF hoodscoop
02-03 STI splitter
Perrin shift knob
Perrin front plate delete
De-pinstriped
Yellow laminex fogs
RA UR mudflaps
^^^^^^ I'd say thats not a bad list for one year, doing all the work myself, and living a "life" also haha…
And for some pics, don't mind the filth, it is after all a SUV!!!!
20FDBC59-8AAF-4358-815F-1C3414AECFA0_zps
4EA5CA90-AA0F-406F-8C3B-865370A01BA5_zps
490E17CC-B9D6-4114-ADDC-516FA7E2C866_zps
F7AD5E91-3095-48D8-A9CF-1E26A7B1BFEF_zps
7233103E-D193-47C9-A077-95623E10BBC7_zps
89975882-93CC-4500-9FA9-54DB2CD18A2E_zps
3EF68916-7C02-4B6F-A18D-EE26129FE369_zps
7221DBA4-B946-49CB-B5F8-80B9963DD2EB_zps
Edited by obk25xt
  • 2 weeks later...
Very nice ride Spencer! You should come down to a PNW Subaru Enthusiasts meet sometime! I sport my rex at several meets throughout the week. Sundays is a huge meet in Portland.
Kickass to see you sportin those numbers! I gotta do injectors, FP and EWG to get my turbo over 12psi.. :(
And then transmission.
Congrats on the purchase!
