disom93 Posted October 11, 2013 Share Posted October 11, 2013 My single range 4speed started leaking where the linkage goes into the trans? How do i fix this or what do i need Link to comment Share on other sites More sharing options...
disom93 Posted October 11, 2013 Author Share Posted October 11, 2013 Can someone help me Link to comment Share on other sites More sharing options...
disom93 Posted October 12, 2013 Author Share Posted October 12, 2013 Bump Link to comment Share on other sites More sharing options...
ferox Posted October 12, 2013 Share Posted October 12, 2013 Are you talking about the shift linkage? If your transmission fluid level is correct, then there must be a wiper seal in there that has degraded. I can't find my FSM at the moment, but this is not a commonly reported malady. Pictures would help a lot. I am guessing this happens after it's been driven. A single range 4 speed is hardly worth opening and fixing unless you are doing a stock resto. Can't remember which bellhousing you have. Not sure if you can get to it without cracking the case. You will probably get more responses if you provide more details. Link to comment Share on other sites More sharing options...
disom93 Posted October 13, 2013 Author Share Posted October 13, 2013 Its a 1980 brat top mount starter. Its leaking where the shifter linkage goes into the trans its dtipping down onto the exhaust behind the cat Link to comment Share on other sites More sharing options...
disom93 Posted October 14, 2013 Author Share Posted October 14, 2013 Anyone have any help Link to comment Share on other sites More sharing options...
