ginsbacht Posted October 11, 2013 Share Posted October 11, 2013 Hi All, I'm a Subie Newbie! Just got my first one-2004 Forester w/93K. Seems good, except... My shop is having trouble fixing my intermittent pull to the right (or left) while at 35-45 mph. They found that the 4 wheel alignment was out, fixed it. And that some bushings were worn, fixed. But I still have the issue. Going back in Monday for the second round. This is a grade A shop, btw. Anyone heard/seen it? Link to comment Share on other sites More sharing options...
subnz Posted October 12, 2013 Share Posted October 12, 2013 (edited) Could be worn steering rack although workshop sould have should have picked this up when doing suspension bushes/alignment , because the suspension was worn it may have caused uneven tyre wear which may be still causing the problem. faulty(out of round) /worn / dissimilar tyre/s , rims, wheelbalancing, wheelbearing/s tyre pressures, dragging brakes maybe? If it is a "Grade A " shop? it should have checked for all these things. Edited October 14, 2013 by subnz Link to comment Share on other sites More sharing options...
