Looking for 5sp D/R plugs pinout
Hello,
I'm working on a swap project (http://www.ultimatesubaru.org/forum/topic/117202-1978-4x4-wagon-build-thread/) and am looking for the pinout for the '89 GL transmission.
I've been looking everywhere and for some reason can't track these down - it's really just two plugs...  If anyone can point me to one or send me one you'd make my life a bit easier.
Or you could climb under the car, undo the plugs where they join the switches, get a multimeter on the "resistance" setting, and make up your own diagram ;)
I'm guess a 5spd, dual range, part time 4wd trans? Because I can remember that there at least 8 different manual transmissions in the L series depending on spec...
If so, you'll at least have:
reverse light power
reverse light signal
4wd power
4wd signal
low range power
low range signal
neutral switch power
neutral switch signal
earth
Edited by wagonist
