punxsutawneylegacy Posted October 13, 2013 Share Posted October 13, 2013 I have a 91 legacy with a 4 speed auto trans. I had the tranny put it not long ago and it worked great for a couple months. Then one day just like someone fliped a switch it only has 3rd gear and reverse. And when its cold and your going down a hill over 40mph it fells like it keeps jumping into reverse. Could this be a shift cellinoid? My tranny fluid is clean and no burnt smell. 1 Link to comment Share on other sites More sharing options...
Legacy777 Posted October 13, 2013 Share Posted October 13, 2013 Welcome to the USMB. Does the power light on the dash flash when you start up the car? If so, the TCU is indicating there is a code stored. Either way, I'd recommend checking to see if there are any codes stored in the TCU. Instructions to pull the codes are on my site. http://www.surrealmirage.com/subaru/trans.html Link to comment Share on other sites More sharing options...
punxsutawneylegacy Posted October 15, 2013 Author Share Posted October 15, 2013 Power light does nothing when i start but i will check the codes anyway. Thank you for the info! Link to comment Share on other sites More sharing options...
Legacy777 Posted October 20, 2013 Share Posted October 20, 2013 Does the power light illuminate at all? It should come on steady with the key in the ON position, but engine not running, should stay lit for a few seconds after startup, and then turn off. Link to comment Share on other sites More sharing options...
punxsutawneylegacy Posted October 23, 2013 Author Share Posted October 23, 2013 No. The power light does not come on at all. Link to comment Share on other sites More sharing options...
presslab Posted October 23, 2013 Share Posted October 23, 2013 3rd and reverse only means that the transmission computer isn't working. No power light confirms it. Check the fuses, the harness plugs by the trans, and the plugs at the trans computer. Link to comment Share on other sites More sharing options...
punxsutawneylegacy Posted October 25, 2013 Author Share Posted October 25, 2013 Where is the trans computer? Link to comment Share on other sites More sharing options...
punxsutawneylegacy Posted October 25, 2013 Author Share Posted October 25, 2013 And what fuse woupd it be? Link to comment Share on other sites More sharing options...
MilesFox Posted October 25, 2013 Share Posted October 25, 2013 The TCU is located on the a pillar(door hinge) behind and to the right of the glove box. Link to comment Share on other sites More sharing options...
punxsutawneylegacy Posted October 25, 2013 Author Share Posted October 25, 2013 All i found to the right behind the glove box was the cruise control box Link to comment Share on other sites More sharing options...
ivans imports Posted October 25, 2013 Share Posted October 25, 2013 sounds like you sheared the end of the band off or smoked the forward clutch pack are you shure its not defaulted into 3rd ? default is 3rd and reverse only 1 Link to comment Share on other sites More sharing options...
punxsutawneylegacy Posted October 25, 2013 Author Share Posted October 25, 2013 The tranny was just installed before i got it from my dad. What do you mean defaulted into third? Link to comment Share on other sites More sharing options...
Legacy777 Posted October 25, 2013 Share Posted October 25, 2013 Check fuse 14 labeled EGI/TCU. Here's a listing of the fuses and diagram http://www.main.experiencetherave.com/subaru_manual_scans/1990_Legacy_Owner_Manual_Scans/118.jpg http://www.main.experiencetherave.com/subaru_manual_scans/1990_Legacy_Owner_Manual_Scans/119.jpg The TCU is under the driver's kick panel. This picture is looking just under the left side of the steering column http://www.main.experiencetherave.com/subaru/images/ecuhide.jpg Link to comment Share on other sites More sharing options...
punxsutawneylegacy Posted October 25, 2013 Author Share Posted October 25, 2013 Ok i found both thank you. The fuse is not blown i even put a nrw one in and still nothing. Plugs at tcu seem ok. Now what? Link to comment Share on other sites More sharing options...
presslab Posted October 26, 2013 Share Posted October 26, 2013 Okay, you should check that the TCU is actually getting power to it. With the key on, check that terminals 14, 1, and 6 have around 12V with a voltmeter. If the voltages are good, maybe your TCU is bad. Get one with the same letter code on the outside; yours is probably an "EE" code. The 90-91 Legacy had different gears in the transmission and the TCU needs to match it. Link to comment Share on other sites More sharing options...
