oakden69 Posted October 13, 2013 Share Posted October 13, 2013 how do i get to the torque converter bolts on 99 forester Link to comment Share on other sites More sharing options...
Turbone Posted October 13, 2013 Share Posted October 13, 2013 Theres a rubber piece at the top left (as you look at the engine)of the bellhousing that covers a hole. Remove the rubber flap and turn the crank till you see the bolts. Link to comment Share on other sites More sharing options...
oakden69 Posted October 13, 2013 Author Share Posted October 13, 2013 kool thank you Link to comment Share on other sites More sharing options...
1-3-2-4 Posted October 13, 2013 Share Posted October 13, 2013 Don't drop the bolts for the TC down in the TC!!! Link to comment Share on other sites More sharing options...
johnceggleston Posted October 14, 2013 Share Posted October 14, 2013 it is way easier if you remove the intake manifold first. Link to comment Share on other sites More sharing options...
heartless Posted October 15, 2013 Share Posted October 15, 2013 it is way easier if you remove the intake manifold first. true, it does make it easier to get to those bolts, but not completely necessary... I simply removed the PCV hoses to provide better access (fewer finger ripping hose clamps in the way, too ) 12 mm offset wrench and out they come. It is also nice to have a helper to rotate the engine and hold it steady while breaking the bolts loose. Link to comment Share on other sites More sharing options...
