removal of torque converter bolts 99 forester
  On 10/14/2013 at 12:32 AM, johnceggleston said:
it is way easier if you remove the intake manifold first.
true, it does make it easier to get to those bolts, but not completely necessary...
I simply removed the PCV hoses to provide better access (fewer finger ripping hose clamps in the way, too ;) )
12 mm offset wrench and out they come.
It is also nice to have a helper to rotate the engine and hold it steady while breaking the bolts loose.
