I'm wondering if anyone with a Legacy in the '95-'99 range that has a sunroof (power moon roof) could post a pic of the emergency tool used to manually open/close the sunroof.
The '95 I recently purchased does not have the tool and I'm trying to figure out what I am looking for or what I can use as a substitute (is a hex head?).
Thanks!
upnorthguy,
Its been years and 3 OBW's since I had a Subie that old, and I can't recall what the tool looked like, but
pull down the center rear ceiling plug. There are several plastic plugs in the ceiling. You want the one back behind where the sunroof would park when it is fully open. It is dead center of the headliner side to side. Shine a light up into the opening, and you'll be able to see what you need. Good Luck!
